E60 transmission fix
Old Dec 12, 2024 | 08:43 AM
  #31
b_e61's Avatar
My Ride: E61 550i M Sport
Default 550i transmission acting funny
No problem
Hello! Anyone here still around?
I have a few issues with my '07 550i (-70k miles)
- upon startup, the gear letter flashes in the cluster. It happens a couple of times and you can hear something trying to "check" near the gear shifter
- the same issue happens when stopped at a light in D, the rpm fluctuates and the car feels like it's preparing to take off (even though it's already stopped)
- the car jerks in low gears and when caught off-guard (e.g. accelerating out of an exit ramp when it had just downshifted - feels like it got confused)
note: when I bought the car, the 1st>2nd gear shift felt a bit pronounced in slightly colder weather. I changed the oil and filter 1 year (10k miles) ago with ZF parts (the old oil was fine and didnt have any shavings). It got a little better then these issues started happening. There are no codes showing up.
What could it be?
Old Dec 12, 2024 | 11:03 AM
  #32
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Check your crankshaft sensor to see if the connector is damaged. Have you ran it for codes? If not I would start there
Old Dec 12, 2024 | 12:35 PM
  #33
b_e61's Avatar
no codes came up last time, clean as a whistle.
tonight i started the car and the gear indicator in cluster was madly flashing and the car had a slightly rough idle (almost felt like a.misfire) then it deteriorated, followed by an EBC error then a transmission fault error. Wtf? Could it be the IVM again? Similar stuff happened last year and I swapped.the IVM with a used unit (which solved them issues until now).
Old Dec 12, 2024 | 02:20 PM
  #34
How old is the battery? What are you using to check for codes?
Old Dec 20, 2024 | 11:37 PM
  #35
b_e61's Avatar
The battery is no more than 2 years old and the indy mechanic uses a code reader (i dont know the name) there were 2 codes that showed up recently as absent 002dca and 002ded Could this be IVM related?
Old Dec 21, 2024 | 12:01 AM
  #36
donpb's Avatar
My Ride: '06 530i N52
2DCA No message, receiver DME, transmitter EGS
2DED DME: Power management, closed-circuit current violation
Source: BMW Fault Code Lookup - BMWFaultCodes
Old Dec 21, 2024 | 12:12 AM
  #37
b_e61's Avatar
thank you, I googled those but not sure what to do with that info?
Another 2 observations:
- the car hesitates/jerks in R (often)
- the car behaves more predictably in DS (i.e. less jerky)
Old Jan 12, 2025 | 08:12 PM
  #38
b_e61's Avatar
I have managed to solve my issue by replacing the IVM and all coils (one was causing a misfire).
Old Jan 20, 2025 | 04:23 PM
  #39
Greggo's Avatar
My Ride: E70 xDrive35i LCI N55 Premium, Comfort Access, Comfort Seats, 4 Zone climate, Vermillion Red
Model Year: 2012
Engine: N55
I fixed my transmission the same way. Dealer wanted a huge sum, fix myself in the driveway. I did not rebuild the valve body, just seals and solenoids.
PaoChe
Feb 2, 2020 05:44 PM
Dvirg10
Jul 1, 2018 02:51 AM
E60Japanese
May 26, 2018 01:58 PM
skullkz
Aug 12, 2014 12:08 PM
Redneck
Dec 5, 2011 08:30 AM
