E60 reverse problem
My Ride: E60 523i
Model Year: 2009
Engine: N52
Hi, i needed help with my e60 523i having issues with reverse. The problem occur after a short or long drive it just won’t reverse/stall unless i turn off the engine and turn back on.
I did change the oil, new filter, all the seal and also solenoids. I scanned using obd it says monitoring clutch B-D
My Ride: E60 523i
Model Year: 2009
Engine: N52
The code 4f82 - Monitoring clutch B and i forget the other code but its monitoring clutch B-D.
My Ride: E60 523i
Model Year: 2009
Engine: N52
My Ride: E60 523i
Model Year: 2009
Engine: N52
I done a lot of research in which, i can’t really find the right answer. Im thinking of doing overhaul or maybe changing valve body separator plate with sonnex kit
Engine: 3.0 B58; 3.0 M54
You are short a couple liters. Did you follow the fill process. If you didn't I would follow it to get the correct amount of fluid in. You should of had to put almost 7 liters in the transmission. Once filled correctly then do a relearn on the transmission via INPA. Drive a couple hundred miles not flooring it and report back
My Ride: E60 523i
Model Year: 2009
Engine: N52
