e60 pre LCI angel eye issue
Drivers side angel side doesn't work. Cannot find the problem. Replaces both bulbs and still doesn't work. If anyone could help me find the location of the angel eye relay or if there is one. The passenger side angel eye works but the drivers side does not.
Thanks
Thanks
Engine: 3.0 B58; 3.0 M54
Did you check inside the headlight assembly for cracked shielding on wiring. It is very common when having these types of issues.
I don't know if you were repeating what I said or making an observation. You're going to have to remove the headlight assembly and look inside to see if the wiring is the issue.
I don't know what the LCM has to do with one side not working.
I’ve already taken the headlight off. The wiring in the headlight is not the issue. I’ve powered the light with external power and it works. The problem I am having is that the angel eye plug in isn’t getting power
Ok got it. Did you put a multimeter on the connector to get to that conclusion. If so you need to get the error codes and post them.
