E60 Parking Sensors not Working - Help!
Hi Guys. I'm looking for help with fixing my parking sensors, front and rear.
Message in car reads "No warning from PDC. Have the problem checked by BMW service"
PDC Issues
Did anything happen recently - like maybe a bump in a parking lot etc that could have damaged a pdc sensor? Make sure they are all clean free from road grit. There is a simple easy - to - do procedure to determine if the fault is a specific PDC gizmo ... google it. Then you can check for electrical connection or bad sensor. Checking out the related module may require swapping out yours with a known good one temporarily.
macantley
03-31-2015 03:44 PM
