E60 Oil Leak
My Ride: 2008 535i Sport
My 2008 535i has started leaking oil pretty badly. After driving it and parking it in my driveway, I have a noticeable puddle of oil under the car.
Took the splash guards off and that big metal plate off from under the engine. Metal plate had a bunch of oil on it.
Ran the engine for a few minutes while I was under the car but couldn't see anything obviously leaking.
Any suggestions on how to locate where the oil is coming from?
Thanks!
Thanks!
My Ride: E60 2006 sedan auto
Oil on the metal cover of your car is a long way forward from the rear main seal and relates to the oil filter seal as previously mentioned
My E60 had two terrible oil leaks when i bought it
the metal pan and all the plastic covers were covered in oil
I changed the front oil filter seal first but the rear main seal is still leaking
I have been driving the car for 4 months and have drips from the rear main seal but not one drop is on the front metal cover.
You can easily check the oil filter seal and do it yourself
I wil pull my transmission next month to change the rear seal
Actually, metal pan on my car is just below engine/trans mounting point. My indy replaced rear main seal and the problem is solved. The oil was leaking badly there, about 2 qt in one week.
Good luck with yours, and thanks for the input!
my metal pan is all the way forward so sorry if my information was of no help.
Yes I must pull mine out very soon
Im not looking forward to it but it is the last oil leak to repair so it will be great when its done
I have to do it by myself so i may take pictures and post about it as it may help others have the confidence to do it also.
Again great news about your car!
