E60 key fob - convert soldered battery to 2032?
Does that mean the CAS module figures out the VL2020 battery is at 90% charge and then kicks in to charge it to 100% (which counts as one of the 1,000 charge cycles)?
If so, now we need to figure out how long (or how many days) the VL2020 can hold a charge before it drops to 90% charged?
donpb (09-24-2020)
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
You say your FOB is 16 years old and working good.
How about your second FOB key that is not used often?
Is that second key also holding a charge after 16 years?
1000 cycles would take longer to reach if only allowed to discharge 1%. How ever many years it takes to fail though, just replace the battery.
My Ride: 2010 BMW 530xi Wagon
Model Year: 2010
Engine: N54
I bought my 2010 E61 with 131K on the odometer it is now at 137K. I was told it was the original battery. Still working fine. I don't know if you can code out the charging function. But just to get that coded if it is an option will cost you X amount of money as well.
I did get replacement VL2020 and soldered it in and it works to start the car, holds charge, etc. !! New problem is that it will not lock/unlock the doors or open the trunk. I've tried every solution I could find to re-initiate it (ignition position 1 for 5x, then holding the unlock down while pressing lock 5x, etc.) but nothing works. Any suggestions? I've come this far, I really don't want to pay the dealer...
My Ride: 528i
Engine: N52k
When you adjust the seat and steering wheel the key FOB should retain those settings.
Is the FOB retaining those settings?
You mentioned, the new VL2020 battery has a new problem it will not lock/unlock the doors or open the trunk.
Is it possible:
- the FOB circuit board got damaged when you split the black plastic cases?
- could you have spilled solder on the FOB circuit board while replacing the battery damaging the door function?
Is it possible:
