e60 headlamps transplant
Old Jan 25, 2014 | 09:24 AM
edwez's Avatar
Default e60 headlamps transplant
Is there a way to install a 2008 e60 headlamp on a 2005 e60 545 ? The connector is different .has anyone done this successfully ? I have a pair of 2008 adaptive headlamp and would like to put them on my 05/545 . Being that the car came with adaptive headlamp I'm thinking there is a way to do this. Also there is An additional plug on the car connection that the newer headlamp does not use. Can anyone share some expertise on this matter ? than you .
Old Jan 25, 2014 | 03:56 PM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
A lot of info about this already.
It's called lci conversion. Do your homework and some research. Definitely not a job you can just bang out if you are not familiar with wiring, reading diagrams, and coding the car.
Old Jan 26, 2014 | 06:22 PM
Bill109's Avatar
My Ride: 2005 525i 6MT
this guy (nomis_nehc) is the person you need to have build the retrofit cables for you.
i have done the same thing, ive go lci headlights and ive had simon build me some retrofit cables! (to which im dying to install... )
Kasmo
May 7, 2019 03:30 AM
mister5kevin
Jul 28, 2015 04:16 PM
jasonkhasnofriends
Apr 27, 2015 12:41 PM
rackhacker9275
26
Apr 16, 2015 08:13 AM
ZeZe
Oct 15, 2003 12:58 PM
