E60 Charging Fault
Old 10-05-2011, 02:26 PM
earcondo's Avatar
I know this is very old, but i have the same problem
I buy a 2004 530i e60, the first problem was the IBS sensor, it was broken (i dont know how).
I think that was the "charge" problem. I Buy a new IBS sensor with adapter (the new model came in 2 parts), and..... same problem....
The problem was the alternator. I live in Paraguay (South America), and the dealer here its a shit.... a new alternator will cost more than 1200 U$, and buy it from USA will take 10 to 15 days AND still cost some 600 OR 400$ (the difference will be a OEM new one, OR an aftermarket).
I take off the alternator and check that have the "voltage regulator" that can be easy take it off (only 3 bolts), i go to a parts dealer and see that it was the SAME from some Audi, VW, and other cars, it cost me 45$ and now runs PERFECT.
I'm new here so i still dont know how to put some pictures to you see which one was the problem, its easy to fix and take me 1 hour to take off the alternator, change the part and mount it again.
This car is a USA version.
PS: sorry if my writing is not good. We speak spanish here
Old 10-05-2011, 10:01 PM
Juttrisky's Avatar
Sorry to hear your guys problems. But if anyones looking for a great used alt out of a 07 530xi,i have it for sale. $400. Thx.
Old 10-06-2011, 06:06 AM
545felix's Avatar
My Ride: 05 545/6
can you post the part# and brand of the regulator (I'm assuming it's a Valeo part since that's who makes the alternator) so that we can find it here in the future?
Old 10-06-2011, 08:48 AM
earcondo's Avatar
Here is some pictures of the original regulator, i show you the # is on it, because i buy an aftermarket one, i dont find the VALEO, but works anyway.
I use this one: http://starterok.com.ua/regulyator-g..._VRPR2292.html (its Chinese)
Here is a list of Valeo regulators, there are many cars that use the same one:
http://www.iat-usa.com/Regulators.pdf
Old 02-07-2012, 06:09 PM
willy beamin's Avatar
So u guys are sure it's the alternator cuz I've been having the same problem and I changed the alternator twice
Old 02-10-2012, 02:55 PM
i bought a brand new bosch alternator from advance auto for 400 bucks now all the problems went away car is good now
Old 04-07-2018, 09:04 AM
Sonpk Yench's Avatar
My Ride: 520d
Model Year: 2010
I got the same problem and I found it come from pulley which was almost pass away : ) sometimes it was free spin that temporary created the problems (charging fault , hard sterring , air-con , low power battery and importantly coolant pump error)
Old 04-13-2018, 01:56 PM
Khoshs's Avatar
My Ride: M5 loaded
Default Battery
I had the same problem when my battery went bad I replaced it and then had to take it in and have them sync the battery to the car the alternator charges at different rates according to a how old the battery is.
Old 02-17-2021, 07:21 PM
Van Davil's Avatar
My Ride: bmw 5 series E60 2006
Originally Posted by saf545
Well my car is currently at the dealer for this issue. I believe its an alternator problem. I will keep you posted.
I had the same problem today and have had 2 alternators changed withing 3.5months so today I did a bit of research. I realized that when the error came on my alternator drive belt had snapped or rather was worn out. I had it replaced and the car is running fine
Old 02-17-2021, 07:22 PM
Van Davil's Avatar
[QUOTE=willy beamin;1418137]So u guys are sure it's the alternator cuz I've been having the same problem and I changed the alternator twice[/QUOTECHECK YOUR ALTERNATOR DRIVE BELT. If its not running then the alternator is not turning hence fault in charging
Quick Reply: E60 Charging Fault
