E60 Airbag Control Unit
My Ride: 540i
Model Year: 2017
Note:
All work on the airbag must only be conducted with the battery disconnected!Connect and disconnect airbag control unit, sensors and gas generators only with the battery disconnected!
The airbag control unit contains vehicle-specific data and must therefore be encoded before placing into operation!Removal and installation in other vehicles is prohibited!
http://www.bmw-planet.com/diagrams/r...0e61/index.htm
Sal-cheeto (04-29-2024)
My Ride: G30 M550i
Model Year: 2018
When you say "control unit", are you referring to the center sensor? There are various sensors/control units for the various airbags, etc.
You may need to be a bit more specific (including what model and year car you have) to be sure you get an accurate answer...
My Ride: E60 550i Sport
have no idea what you call the gateway unit. Once the airbag was deployed you have to replace to airbag control unit because this is where the error is stored.
My Ride: 525i
how did u remove the arm rest and stuff? i tried looking for some bolts but couldnt find much... i need to check the serial number on my car so i could order the same one... if you could tell me quick tips to get to the unit it will be very helpful. thanks!!
DavaiLave
08-02-2022 02:16 AM
