e60 545i check engine code P0491
hahaha, so i look at mine and i forgot to connect it back up. DER
I drove pretty "spirited for over a year on the z4. Clearing like every week because I can't stand dash msgs
![](https://5series.net/forums/public/style_emoticons/default/doh.gif)
I had this problem on my M54 engine. I had the tube / valve replaced and decided NOT to replace the secondary air pump at all. It does whine on cold starts for about 5-10 seconds and I could care less. It hasn't failed yet and I won't replace it until it does. Even then, I don't need it unless I HAVE to pass emissions.
Funny thing about the loud noise on start, too.... My friend was like, "dude, what is that?" I said, "oh, it's the supercharger winding up." His reply, "wow, that is badass!"
I really had to hold back from laughing.
My Ride: '04 545i, sport pkg, premium sound, sprint booster,
I've been having this problem for the last few months. Everything was replaced, car runs fine. So I'm guessing there is a loose connection to the pump? Difficulty for checking this?
Its not too difficult but you have to disconnect a lot of connectors before you can get to the pump. Give yourself 4 to 5 hours if this is your first time
My code is p0492. The 1st post by the guy named the newbie has a 1 at the end. I'm gussing one is right and the other left. But wich one. Before I got the code checked I looked at my pcv and the left side was ripped. Then when I felt proud of the easy fix I got kicked in the balls with a unrelated code.
