E60 535d vs E39 M5
Old 01-22-2006, 05:48 PM
0700700's Avatar
well to say the least, quite suprising. I have raced an e39 M5 on the highway from kilometer 93-109 (sofia >>> plovdiv), and he took me from the start and at around 220 he was at least 50 meters in front of me. His limiter hit in at 260 and only then was i able to pass him, eventually reaching a speed of 289km/h on the speedo (274km/h by gps).. And i was with a... e46 m3 smg coupe with sports mode on / DSC off and shifting pattern 6.
And i used launch control at the last set of traffic lights out of the city, onto the highway..
And sorry mate, but i highly doubt it that the 535d accelerates anywhere near as fast as the chipped m3 (354bhp)... So i dont buy it, unless the m5 has had 250000km on the odo , and has lost about 250ponies... or he simply takes 3 seconds to shift gears
Originally Posted by big_ipaq' post='227912' date='Jan 22 2006, 07:29 PM
By the way... Here's the M5: http://www.bmwm5.as.ro/
sure doesnt look like it has 250000km on the odo
0700700 is offline
Old 01-23-2006, 12:12 AM
cidair's Avatar
535D ROCKS!
It must have one of the best fuel mileage vs. performance there is?
cidair is offline
Old 01-23-2006, 12:32 AM
BetterMakeWay's Avatar
Originally Posted by cidair' post='228162' date='Jan 23 2006, 04:12 AM
535D ROCKS!
Hahaha it surley was. Consumption before the "race" 10.9l/100km in city drive. traffic was light as it was sunday. After the race 14,1L/100km. Nice. Anyway i don't care too much about fuel consumption in exactly those kind of moments.
BetterMakeWay is offline
Old 01-23-2006, 12:37 AM
juliann's Avatar
My Ride: 535d Sport Tourer - E34 M5 Race Car
I suspect the M5 smoke was oil smoke. My E39 M5 could burn 1 litre every 700 miles in hard driving. Believe it or not, this was within BMW tollerences !
juliann is offline
Old 01-23-2006, 12:42 AM
[/quote]
I didn't say anything about a chipped m3. I said what happened with an e39 m5. He was obviusly quicker than me, but the underlined thing it was the fact that i could cope very well staying right with him in the very 1st couple of seconds of accelerating. We floored it from 100km/h onwords. So if it would have been a stand still race the gap would have been more than huge. Damn, i pay alot and i mean ALOT of respect for the m cars and i don't say it because i own a 535d, i'm fairly objective on this. It was like i could stay with him for at least 2 gears. Only after that he starts to pull away from me. Also as the speed got higher the ability of my car to keep up even if he would have been right beside me, became smaller and smaller. But to make myself clear i was amaized by the way i could keep up at moderate speeds especially from overtaking manouvers.
Yes i also suspect that. There's nothing else there could be. Also the black smoke came only at peak revs. Despite the fact that i had my music turned on almost at max, and the engine of my car in full throttle i was still able to hear a glimps of the v8 roaring at high revs. That was when in every gear the smoke came out.
Old 01-23-2006, 01:32 AM
0700700's Avatar
re-read my post. i raced a stock e39m5 with my chipped m3 smg coupe...
0700700 is offline
Old 01-23-2006, 01:41 AM
[/quote]
Sorry missunderstood. Still morging u know...
From what i understand u raced that guy with ur m3 from a stand still start. So given that of course i said if i would have done it from stand still the guy would have smoked me by far. I just said about the braking/accelerating/overtaking manouvers. If u don't buy it...sorry i don't lie. That's the exact thing that happened.
Bigipaq if u know the guy and it's an active member on bmwclub.ro tell him to pay us a visit to clarify things...
Old 01-23-2006, 01:49 AM
0700700's Avatar
[/quote]
i just dont. The m5 revs to 7100-7400rpm (depending on tune) , it generates 500nm , it has 400bhp, and it weights less than the 535d... Unless he does not know when to shift down, to explore the maximum potential of the car then you have NO chance... even in overtaking.
I have raced a corvette z06 which does 0-100 in 3.8seconds, and an m6 and won... Why? because the people that drive them are 16-18, and they cannot or are scared to drive daddys car...
You have a steptronic, and you were in DS, as soon as you kicked down on the gas you downshift, whereas he keeps the same gear... I have raced a 330d from a start of 120km in 6th gear and no surprisingly he kept pulling away , until i got into 4th
engine V8
valvetrain DOHC 4 Valves / Cyl with Double VANOS
displacement 4941 cc / 301.5 cu in
bore 94.0 mm / 3.7 in
stroke 89.0 mm / 3.5 in
compression 11.0:1
power 293.8 kw / 394.0 bhp @ 6600 rpm
hp per litre 79.74 bhp per litre
bhp/weight
torque 498.94 nm / 368.0 ft lbs @ 3800 rpm
redline 7000 rpm
drive wheels Front Engine / RWD
body / frame Unit Steel
front brakes Vented Discs w/ABS & Vacuum Assist
f brake size 345 mm / 13.6 in
rear brakes Vented Discs
r brake size 328 mm / 12.9 in
front wheels F 45.7 x 20.3 cm / 18.0 x 8.0 in
rear wheels R 45.7 x 24.1 cm / 18.0 x 9.5 in
front tire size 245/40ZR-18
rear tire size 275/35ZR-18
steering Speed Sensitive Recirculating Ball
weight 1795 kg / 3957 lbs
wheelbase 2830 mm / 111.4 in
front track 1514 mm / 59.6 in
rear track 1527 mm / 60.1 in
length 4784 mm / 188.3 in
width 1801 mm / 70.9 in
height 1412 mm / 55.6 in
transmission Getrag Type D 6-Speed Manual
gear ratios 4.23:1, 2.53:1, 1.67:1, 1.23:1, 1.00:1, 0.83:1
final drive 3.15:1
top speed 249.4 kph / 155.0 mph
0 - 60 mph 4.8 seconds
0 - 100 mph 11.3 seconds
0 - 1/4 mile 13.3 seconds
epa city/hwy 13 / 21 mpg
0700700 is offline
Old 01-23-2006, 02:15 AM
big_ipaq's Avatar
I will...
big_ipaq is offline
Old 01-23-2006, 05:18 AM
I will...
[/quote]
Good!
Quick Reply: E60 535d vs E39 M5
