Driving Stability Malfunction
#31
I forgot to add. When you replace battery, hold the + and - cables on your car for one min before installing new battery. You may just have to reset clock. Radio stations and everything will most likely stay put. If you still have the error take a code reader and clear all codes. It may not pop back up to your surprise. I've had to do this before so it's sound advice.
#32
so where is steering angle sensor located at and can you provide in detail how did you remove and clean it?
#33
Probation Members
My Ride: BMW X5
please help a newwbiee
I am having an intermittant problem with 2007 530I. What is happening is that I am getting a yellow triangle inside a circle and the word "brake" in yellow on my dash See attachments). When I look at the service indications in the iDrive system (in the nav window area), there are two messages. The first is "Drive control system! Drive modera . . ." When I click on this message it takes me to a screen with a message that says "Driving Stability - Drive control system malfunction. Reduced driving stability in curves. Drive moderately! Have the system checked by the . . . "(you get the idea). The second message in the main "service" indicator area says "Start-off assistance inactive!" When I click on it, the next screen says "Start-off assistance - Start-off assistance inactive. Caution, vehicle may roll back! Have the system checked by your BMW center at the next opportunity." The car does NOT go into limp mode and appears to drive normally.
Attachment 110253Attachment 110254Attachment 110255Attachment 110256Attachment 110257
- DSC module and pump,
- Alternator,
- Wheel speed sensor,
- Wiring harness,
- Brake light switch,
- Weak battery, " you may find complete details of fixes at youcanic. hope it helps.
Awest91
09-17-2022 11:05 PM
TexaZ3
05-06-2015 09:54 AM
