Drivers airbag light?
Got airbag light on and had the codes read......
94CA
0x6E6294CA 94CA Resistance, firing circuit, driver's airbag, stage 1, too low
94D5
0x6E6294D5 94D5 Resistance, firing circuit, driver's airbag, stage 2, too low
Anyone know what the fix is for this?
94CA
94D5
Just read on another forum some guy had removed his steering wheel and hadn't pushed the connectors in tight enough and got similar codes, so i'm gonna disconnect the battery for 10 minutes and remove it and check wiring.
Probation Members
My Ride: 88 325is, 04 545i, 07 328i, 08 x5 4.8
I just Took the airbag plug apart, there are two metal tabs that short the circuits when unplugged, I removed them, and both codes went away. This is a old thread, but if someone comes across this. It fixed mine, not sure why it's not pulling the tabs out of the way when plugged in, but now she good to go.
