driver side license plate light not working
My Ride: E60 530d
My Ride: 528i
Model Year: 2010
Yes exactly that - if the wires were actually touching and shorting each other, the light module would have disabled that circuit if it happens 10 times in a row. Make sure the problem is properly fixed before resetting it, I think you can only reset it 4 times before it permanently stores the fault code.
Look up the colours in WDS if you want, brown is ground in the headlights of my car...
My Ride: 528i
Model Year: 2010
My Ride: E60 530d
try DIS first?
Tool32 is confusing indeed, I've never used it, please be careful as apparently it's easy to press the wrong thing in that too. However it does operate at a lower level and should be able to force clear it. Read up on how to use it? If you find any guides let me know!
Random idea: try coding it with a blank .MAN file (or use ncsdummy to change cold check to not activ for a certain bulb e.g. the angel eyes) in NCSexpert - the LMA resets itself every time you code it so maybe that will do the trick.
My Ride: 528i
Model Year: 2010
try DIS first?
rizwan1377
04-05-2015 05:22 PM
