Driver Seat - No Power
My Ride: 04 545i
I went to pick up my car from the tinting shop where I had Formula One Pinnacle installed. After checking their work, I went to sit in the driver seat, but the seat had been adjusted, so I couldn't fit it. I guess in order for the installers to have adequate access to the back seat, they moved both Sport Seats (20-way), to the full forward, max height position.
I went to adjust the driver seat back (I'm 6'-3", so I need it all the back and lowered), and nothing happened. I checked all the buttons, but still, it was dead. I went around to the passenger side seat, and it adjusted fine back into its normal position.
Of course the shop verified they moved it up, but could not explain why it suddendly became inoperable. It was late, the shop was closed, and no dealers where open, so I was forced to drive the car home with the seat in a position not even suited for the smallest of humans.
Anyway, there are no I-Drive errors, and I've looked under the seat to make sure there is no debris in the seat tracks, so I completely stumped.
This obviously sounds like an electrical issue, but the timing of this failure is somewhat suspect. Does anyone have any idea why my seat is dead?
Thanks in advance for any responses.
Patrick
Patrick
My Ride: '05 545 Titanium Silver, Black Leather - Nav, Logic 7, Cold weather.
Mods:
Carbon filter removed.
M5 iDrive knob.
Umnitza license plate LEDs.
MP3
40% 3M tint
ACS Anti-Roll(sway) bars
RPI Scoop
G-tech Pro RR
CF Roundels
CF Wheel caps
Patrick
Patrick
Have a look under there and see if its something obvious like that.
Wouldn't it have been smarter to leave your car at the shop and see if they can fix it for you in the morning? If anything, they should still be responsible for it. The shop even said one of their mechanics adjusted it while doing the rear window. So the shop openly admitted to you that it was operational when the shop had it under their care. But you drove off with it anyway leaving the obligation for them to fix it no longer mandatory. If you could of actually fix it when you drove it off, I get why you accepted your car but you didn't. You made your ride inconvenient for yourself and probably will again when you drive it to BMW or back to the shop to get it corrected.
![Arrow](https://5series.net/forums/images/icons/icon2.gif)
I'm picturing someone's foot slipping in under your seat as they sit in the back and contort their body to put on your window tint to the back window. Probably focused on their work and may have been unaware of what they were rubbing up against or even pressing with their feet or foot.
Have you gotten behind your seat with a flashlight in hand and looked for any hanging wires or anything unplugged? Maybe compare the back under part of the driver's seat to how it looks under the working passenger seat? Maybe a BMW mechanic or SA can tell you over the phone where the power connection for the E60 seat is located?
Just throwing out ideas. I think it will end up being something simple ... Hope so. Let us know how it turns out. GL.
My Ride: 04 545i
I had a choice; leave my car in a tint shop til Monday (no friggin way), or get into a fetal position, and drive home. I chose the latter.
My Ride: 04 545i
I'm going to checked it out in the morning with a flashlight. All signs point to a loose connection. If not, its off to dealer on Monday. Thank for the comments.
Originally Posted by joojoobee' post='628335' date='Jul 20 2008, 01:21 AM
That's exactly what I was thinking. It even looked like they dislodged the seat guiderail plastic cover a bit. I jiggled that around, and it snapped back in place.
Thanks
My Ride: 04 545i
Originally Posted by sosohappy' post='643379' date='Aug 10 2008, 01:11 AM
Hi, can you please let us know the results, because I am afraid I might have the same problem
. Yesterday the passenger seat was moving fine in all 1001 different directions
, but now somehow all the power seems to be lost because it is not doing anything. So I was kinda hoping that you could give us an update.
Thanks
Thanks
I was at the dealer last week for another issue, and had them check the seat for shorts, and other possible damage. The tech guy confirmed that the wires were in good shape, and what I did most likely resolved the issue. Hope that helps.
TexaZ3
05-06-2015 09:54 AM
