Dripping fluid by passenger front wheel well
Old Apr 12, 2009 | 06:46 PM
Pauken4's Avatar
My Ride: 2009 535xi Platinum Gray. M sport, Premium, Cold, Logic, PDC, Sirius, and Bamboo.
From day one, my new car seems to be dripping fluid from under the passenger front bumper near the wheel well.
I have not had the AC on and thought it strange. It seems to be the consistancy of thin oil and is staining my garage floor. I was changing my fog bulbs today and got a closer look. The underside of the plastic panel on the passenger side of the bumber has slats in it as if it was designed to allow this stuff to drip down there.
Could this benormal?
Anyone know what this stuff might be? I was planning on putting a HID ballast in that space, I am now not sure I want this stuff bathing the ballast.
Thoughts?
Old Apr 12, 2009 | 07:02 PM
ObD's Avatar
ObD
My Ride: 2008 535i 6MT
Doesn't sound right. I think you may have an oil leak. I know there are oil lines that run near the radiator. Also could be a coolant leak or AC leak. I'd take it to the dealer and see what they say. It could be just cosmoline that they spray the car with when shipping too.
Old Apr 12, 2009 | 08:09 PM
jagbagri's Avatar
Thoughts?
I'm not if its the same but I had the similar leak somewhere around the front wheels. Not very much, just a drop or two during the night. They replaced the sway bar under warranty. No more leaks.
Old Apr 13, 2009 | 04:45 AM
Pauken4's Avatar
Thanks.
I guess having a 15" puddle under the car every morning isn't normal. I'll take it in to be looked at.
Old Apr 13, 2009 | 09:23 AM
flyingpuck's Avatar
Could this be excess Cosmoline???
Old Apr 13, 2009 | 09:28 AM
z06bigbird's Avatar
Halogen fluid is also a possibility. Did you overfill the headlights?
Sometimes muffler bearings fail and leak, but they are further back under car.
Old Apr 13, 2009 | 10:01 AM
flyingpuck's Avatar
Perhaps even "Blinker Fluid"!!
blinker fluid
For your sake I hope not as they are out of stock on the stuff!
Old Apr 16, 2009 | 05:41 AM
Pauken4's Avatar
The transmission oil heat exchanger was leaking.
Old Apr 16, 2009 | 06:25 AM
545felix's Avatar
My Ride: 05 545/6
that is frightening on a MY2009.
Old Apr 16, 2009 | 07:34 AM
Pauken4's Avatar
Nothing is perfect, I guess.
Kasmo
May 7, 2019 03:30 AM
cointilt
Mar 30, 2015 10:50 AM
androulakis
F10 Discussion
Mar 28, 2015 03:30 PM
jhalsey
Jan 25, 2004 04:34 PM
