Do you have any experience with tire sealant?
My driver's side front and rear tires must have some kind of small leak in them because they each lose about 10psi after about 10 days.
I thought about using tire sealant, but is it safe to use on our cars? Mine doesn't have TPMS but it does detect when the tire is flat.
What do you guys think?
Also, what's a good tire sealant? I'm debating between Slime or Ultra Seal.
+1 on not using tire sealant. If you ever need tires replaced, most (if not all shops) will charge extra if you've used tire sealant. Just give your local tire shop a jingle and ask them what their stance on tire sealant is.
+2 ... some leaks are difficult to detect unless the work is done by a pro who has the right equipment and takes his/her time.
DavaiLave
08-02-2022 02:16 AM
DetailersDomain
05-22-2015 04:00 PM
kurtb23
04-22-2015 04:30 PM
