do our key fobs lose battery
Old Jun 28, 2009 | 10:42 AM
Diamond's Avatar
Banned
Do our key fobs every lose batter? and I was told I believe that they charge by sticking it into the ignition? I have CA and rarely if ever plug my key in as it sits in my pocket but the other day I got a message on my car screen that looked like a key fob with a battery symbol or something. Can they be charged by sticking it in the car
Old Jun 28, 2009 | 10:45 AM
lorinzo's Avatar
Yes.
Need to put in ignition every now and then to charge.
Old Jun 28, 2009 | 10:54 AM
seabass79's Avatar
I believe w/ comfort access it will not charge when you put it in the ignition. You can pop off the cover on the back of the fob and a small battery goes in there.
Cars without comfort access will charge when you put the key in the ingnition.
Old Jun 28, 2009 | 11:47 AM
luigi524td's Avatar
Thumbs down
Originally Posted by lorinzo' post='926517' date='Jun 28 2009, 02:45 PM
Yes.
That's only standard fob - the Comfort Access key fob uses a replaceable watch/remote control type battery ... easy to find (Radio Shack, etc), no-fuss and cheap replacement; my primary fob battery lasted about 2+ years/
Old Jun 28, 2009 | 11:59 AM
Krozi's Avatar
Standard key: Yes
The manual states you should use the spare key at least once a year.
Comfort Access: Yes but it has an interchangeable battery.
Old Jun 28, 2009 | 12:07 PM
DD_545i's Avatar
Does this charging apply to pre-LCI cars too? I had no idea.
Old Jun 28, 2009 | 12:11 PM
Krozi's Avatar
Yea.
Old Jun 28, 2009 | 12:18 PM
DD_545i's Avatar
Originally Posted by Krozi' post='926599' date='Jun 28 2009, 10:11 PM
Yea.
Thanks. Good to know.
So if for some reason I have to switch to my spare keyfob, I'll expect it to not unlock the car initially.
I'll have to do a test with that tomorrow, see if my (after-market) car alarm is turned off from turning the key in the door.
Old Jun 28, 2009 | 12:19 PM
Krozi's Avatar
It should deactivate the aftermarket alarm when using the actual key hole.
Old Jun 28, 2009 | 07:14 PM
Bdaddylo's Avatar
My Ride: 07 550i Titanium Silver, Black Dakota Leather, Steptronic, Sport, Premium, Nav, Sat. Radio, Logic 7, Comfort Access, Rear Sunshade.
Originally Posted by Krozi' post='926588' date='Jun 28 2009, 02:59 PM
Standard key: Yes
Interchangeable batteries aren't rechargeable; hence, CA FOBs don't charge when placed in the ignition.
