Do non-OEM wheel sizes affect the DSC?
Old Apr 2, 2010 | 11:36 AM
UncleFodder's Avatar
My Ride: '07 550i
Just curious - running certain, different size wheels on Corvettes can trigger the traction control. The car believes the tires are slipping due to the rotation differences versus stock sizes. Can/Does this happen on E60's with aftermarket wheels?
Old Apr 2, 2010 | 02:19 PM
trex's Avatar
Hi.
My first thought would be no, since the DSC measure the speed of each wheel and compares it to detect any wheelspin/slip. It also compares this to the steering wheel angle to measure out which wheel to brake if the car skids.
The only harm non-OEM wheels whould do, is t make your speedo show a "wronger" speed.
Tommy.
Old Apr 2, 2010 | 03:10 PM
pukka's Avatar
My Ride: 2008 535i: (8/07 Build) Metallic Bronze, Beige NASCA Leather, Ventilated Seats, Sport Pkg, Cold Wxr Pkg, Logic-7 Sound, HUD, Night Vision, PDC, Split Rear Seats, NAV, Premium Pkg, Comfort Access, HD Radio, Sport Auto Trans Current mods: M-Aero Kit, JB4, Motorcepts 6000k HID Foglamps Umnitza ICE-Lite 10w LED 6000k AE's 1992 Camaro RS: Fully Restored w/Custom Interior, 5.0L V8, T-tops, OEM Z28 Foglamps, Inst Cluster, & Spoiler, Custom Sound, Too many engine mods to list
It's been awhile since I tinkered with drive ratios - bu I'm pretty sure if you run larger rims, then you need lower profile tires to keep the wheel diameter the same, otherwise your speedo/odo will be off until you get it recalibrated.
I don't think DSC would engage since it checks for the difference in rotation speed between right and left, which would suggest slip. Hopefully someone with larger aftermarket wheels on their car can chime in.
Old Apr 2, 2010 | 04:15 PM
pjinca's Avatar
I run 20" wheels and it doesn't trigger the DSC. That said, I would suspect you could trigger it if you run rims/tires outside the 1-3% of stock rolling diameter. The difference in size could affect it, but my wheels/tires are not big (or small) enough to trigger it.
E60Japanese
Jan 20, 2025 04:23 PM
riches
Apr 20, 2015 05:08 PM
E60Japanese
Mar 23, 2015 05:23 PM
new_e60
Nov 6, 2003 04:35 PM
