DIY 545i secondary air valve replacement
#21
![Question](https://5series.net/forums/images/icons/icon5.gif)
I wanted to know were there any updates on whether or not some actually fixed the dread P0492??? I like everyone here am having the same issue. Secondary Pump, works, tubes are crack free. Only thing I haven't done was change the check valve and do the carbon clean with that snake type brush.
Thanks in advance my fellow V8 owners!
#22
My Ride: Orient blue '05 545i, Sport/Premium Pkg, 6Speed MT, Xenon, Navi, Blue2th, PDC,
How many miles do you have on your car?
#23
My Ride: BMW E 60
so your saving some money there as apposed to having both codes and having to change both valves.
its uncomfertable to replace them . they are hidden behind the engine tight agains the firewall.
have it replaces. and you will be good to go.
careful not to break any hoses in the process creating a leak.
i would do it as soon as you can. as a bad check vavle can cause the secondary pump to fail over time. then your out another 300+ dollars.
thesalboy
04-08-2015 09:13 AM
