Ditching the run-flats
My Ride: 2005 545iA
Originally Posted by TopBanana' post='613492' date='Jul 1 2008, 12:14 PM
Do BMW sell these? If they do, I expect they'll cost an arm and a leg.
cu rumman
My Ride: Estoril Blue 440i GC
Model Year: 2017
It depends on how much of a cheapskate you are!!
You can talk with your local tyre factor (I don't mean ATS!!) - mine supplied me with a new BMW wheel and Continental tyre for ?85. I had a wheelbrace anyway. I often carry a hydraulic jack, but I also use a Vauxhall Omega (I presume the Carlton/Vectra ones are the same ; check the safe working load stamped on it) item. Three minutes with a Junior Hacksaw shortening the plastic top to the jack so it fits snugly into the jacking points on the sills and off you go.
If you go to BMW you will get a plastic tray that holds the jack, and also wheel chocks.
Mike
Mike
