Directional Indicator design flaw
Old Apr 11, 2005 | 06:47 PM
  #31
TitaniumGray5's Avatar
My Ride: '05 545 Sport Week 9
The indicators work great IMO..yes, they are a little different, but once you read the manual or learn how to use them, they are great. In regards to hand position, if you have your hands where they are supposed to be (3 and 9 O'clock) for proper driving and airbag safety, they will not block the indicators.
Old Apr 11, 2005 | 10:21 PM
  #32
CoolTones's Avatar
My Ride: 2008 M5 -- Exterior: Silverstone, Interior: Black. Fully Loaded. That just about sums it up! :-)
Originally Posted by Rudy' date='Apr 11 2005, 06:25 PM
But then again, the I learned that the E60 wiper stalk also does the same thing. BIG DIFFERENCE though is that at least you can *SEE* the wipers going!
[snapback]113385[/snapback]
Huh? What did the wiper stalk do? I'm not sure I understand what you're saying.
Also, you do get used to the turn signals. For me, it's like everything else in the car (iDrive, SMG, Active Steering, etc.) -- it's different -- if you're resitant to change, then you'll have a hard time with the car. If you accept change and allow yourself to adjust, you'll find that these "new" designs end up being better than the old way of doing things. As far as the wheel blocking the green lights, yeah, they could have been placed better.
I will say that if they'd have made the audible clicking louder or through the speakers, there would be people complaining that it's too loud and they'd be calling that a design flaw...
[snapback]114331[/snapback]
[/quote]
When the turn indicators are activated, the *green* directional light flashes but you can't see it. Turn the windshield wipers on and you *see* the wipers going back and forth on the windshield -- That's what I meant about *seeing* the wipers...
Making comments about change does not make one *resistant* to change, but merely one who *notices* change I very much like the design changes that BMW has done to the 5-series. The fact that I will now be able to haul 4 golf bags at once is a good change!
As you pointed out, you can't please everyone.
Old Apr 12, 2005 | 01:15 AM
  #33
skaffa's Avatar
My Ride: -04 530D
Originally Posted by Iceman' date='Apr 6 2005, 02:05 PM
I am 6'26'' and can see everything clearly. Signal indicators, all the tachs and the indicator for the rain sensor.
The only thing I can't see is the indiciator for the heated steering wheel, but THAT I can feel...?
[snapback]111816[/snapback]
Huge tall You are Iceman (255cm). Maybe typo?
Only "problem" is that sometimes I, by mistake, use turnligh lever for cruise and car coming ahead get flashed.
Skaffa
Old Apr 12, 2005 | 03:03 AM
  #34
cobradav's Avatar
Originally Posted by skaffa' date='Apr 12 2005, 03:15 AM
[quote name='Iceman' date='Apr 6 2005, 02:05 PM']I am 6'26'' and can see everything clearly. Signal indicators, all the tachs and the indicator for the rain sensor.
Skaffa
[snapback]114395[/snapback]
[/quote]
I have done that a couple times as well. My wife?s Audi is the same set up so I was already partly trained but still do the accidental flashing a little more in her car. The 6er set up is an improvement over the Audi, plus the actual CC is better in the BMW. Overall I like the layout, and even though I do not always see and hear the turn signal I sense that it has done what I asked of it either in the lane change or full turn (past detent). I also sense when I hit the detent and did not intend to, so go again in same direction to cancel. Again, after a while it just seems second nature to me. On the other hand, when I get into my archaic US made products (truck and older sedan to cart around dogs) I keep trying to use the change lane feature ? oops don?t have it, and the push/pull CC ? oops don?t have that either. Oh well, some day the rest of the world will catch up.
Old Apr 12, 2005 | 03:10 AM
  #35
mflauer's Avatar
My Ride: 2004 Titanium Gray 545i auto, navigation, premium sound/Logic7, cold weather, adaptive Xenon, Lumbar support, split rear seat, PDC.
Originally Posted by Guest' date='Apr 5 2005, 11:59 AM
[quote name='nomad' date='Apr 5 2005, 01:29 AM']I can't tell you the number of times I've indicated, only to turn in, out, or around and find out that the indicator didn't indicate, or I didn't press it hard enuff so it only flashed 3 times while I waited to perform a manoeuvre.
[snapback]111274[/snapback]
You can turn off the 3 time flash in iDrive so that the indicators work like they do in other cars (I turned this feature off). I don't have any problem either seeing the indicators or hearing them (a synthesized mechanical relay switch is broadcast over the speakers), so they work just fine for me.
[snapback]111431[/snapback]
[/quote]
You don't have toturn it off. If you hold it down it works like a standard signal.
Old Apr 12, 2005 | 03:13 AM
  #36
mflauer's Avatar
Skaffa
[/quote]
That's an easy mistake to make especially in the beginning.
Old Apr 12, 2005 | 03:42 AM
  #37
skaffa's Avatar
My Ride: -04 530D
Not beginner anymore, but maybe slow to learn!
Skaffa
Old Apr 12, 2005 | 04:58 AM
  #38
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Originally Posted by CoolTones' date='Apr 12 2005, 02:21 AM
[quote name='Rudy' date='Apr 11 2005, 06:25 PM']
[quote name='CoolTones' date='Apr 9 2005, 01:36 PM']
But then again, the I learned that the E60 wiper stalk also does the same thing.? BIG DIFFERENCE though is that at least you can *SEE* the wipers going!
[/quote]
[snapback]114376[/snapback]
[/quote]
I understand the difference in what you can *see* between the turn signal indicators and the wipers. I don't understand what you mean when you say "the E60 wiper stalk also does the same thing." What does it do that's the same as the turn signal stalk?
Also, I didn't mean to offend you in any way with my comment about people who are resistant to change. It wasn't aimed at you specifically and it wasn't meant to be a negative. I think we all are resistant to change to some degree. The E60 is advanced in many ways -- at the beginning of ownership, things that are different on the car are quite noticeable and evident and often times people complain about them. (I may have misunderstood your comment as being critical.) Next week I'll have had my car for a year. All those "different" things are now second nature and, in most respects, I prefer them over the older way. My point was that I see many people complain early on about something but usually later on they adjust to things and realize the benefits of the new design (see also: SMG ).
Again, I'm sorry if I offended you...
Old Apr 12, 2005 | 08:51 PM
  #39
CoolTones's Avatar
Originally Posted by Rudy' date='Apr 12 2005, 05:58 AM
[quote name='CoolTones' date='Apr 12 2005, 02:21 AM'][quote name='Rudy' date='Apr 11 2005, 06:25 PM']
[/quote]
[/quote]
[snapback]114439[/snapback]
[/quote]
Hi Rudy,
Thanks for the reply. What I meant about the *same* was that both the turn indicator stalk and wiper stalk both snap/return back to center position once you let them go. Unlike my '98 BMW the stalks when moved in either the up/down direction stays there until you manualy flip them back to center. So no it's been a couple of days since my original post -- I've since driven a 545i a couple of more times (Well, I *have* to drive it a few more times to see if this is really what I want, right? ) and now as I drive my current BMW I'm wishing controls operated like the E60!
I'm looking forward to day I can place my order.
Cheers,
Tony
Old Apr 13, 2005 | 05:40 AM
  #40
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Tony, I think you might be confused as to how the wiper stalk operates.
If you push it down, it will wipe once and snap back to center but if you push it up one click, it will stay there and the wipers will be on slow speed. You can push it up a second click and they'll be on fast speed. From the center (off) position, you can press the button on the end of the stalk to activate the rain sensor. In that case, the stalk stays in the center but a green LED illuminates on the stalk. The sensor sensitivity can be adjusted with the thumb dial on the stalk as well.
You're right that after a while, other cars start to feel strange...
edit: Just today I realized that I was wrong about the way the wiper stalk works. Tony is right, it does return to center. In the E39, it operated the way I described above but I never use anything except the rain sensor so I didn't realize they changed it. Oh well, now I know...
