Is That Dipstick back?
Old 05-17-2009, 11:55 PM
  #31
daven's Avatar
The diesels have them!
Old 05-18-2009, 04:38 AM
  #32
melimel's Avatar
Originally Posted by GENEaTALS' post='881531' date='May 17 2009, 10:15 PM
show off.. im typing this as i sit in the stealership.. brakes still squeaking and frankly an embarrassment, back seat just folded foward and wont stay back(must be all the bodies i hide in it) and sunroof seal is popping up a little.. and no loaner
Old 05-18-2009, 06:21 AM
  #33
Veight's Avatar
Originally Posted by DrLev99' post='881322' date='May 17 2009, 05:26 PM
It was my understanding that the dipstick came back with the LCI, but I am not sure if earlier models had them and if it disappeared in between somewhere. I know my '07 530xi did NOT have one. Rudy should know.
The V8 550 always had a dipstick. On drivers side of engine at the firewall.
Old 05-18-2009, 06:23 AM
  #34
Veight's Avatar
Originally Posted by Richard in NC' post='881429' date='May 17 2009, 07:18 PM
In my '08 550i, it's in the back left (passenger side). It's low and not marked but it is an oil dipstick.
Passenger side? I think thats your tranny dipstick.
The 550's have them on the Drivers side at the firewall.
Old 05-18-2009, 07:22 AM
  #35
porsche911targa's Avatar
Originally Posted by DrLev99' post='881639' date='May 18 2009, 12:52 AM
Like Rudy said, maybe only the V-8's have them.
Do the V8's have aluminum-magnesium engines?
Old 05-18-2009, 08:00 AM
  #36
z06bigbird's Avatar
Originally Posted by juris335' post='880905' date='May 17 2009, 08:29 AM
Some member posted that the dipstick is returning. We now have Members in possession of shinny new 09s. Is the dipstick back? If it is back I wonder if it can be retrofitted on older models?
No,sir. He has moved to another forum.
Old 05-18-2009, 09:20 AM
  #37
MiamiPhill's Avatar
Originally Posted by ObD' post='881117' date='May 17 2009, 03:19 PM
I've never had a problem with the electronic oil level sensor and have found it to be quite accurate. I check my oil level much more often with the e-gauge while I sit in traffic and prefer it.
You have found the electronic oil level sensor 'to be quite accurate' .......really? how can you tell, what are you using as a comparison.
Old 05-18-2009, 02:59 PM
  #38
krusir's Avatar
My Ride: 2009 535xi, short shifter, no CDV
I personally don't trust the sensor very much. Anyone knows how it works... It check the level during engine run time ( while drive ) ... at this time, depend on the rev. of engine, the oil is pump to the top and all different places.... How do the sensor knows the last litter (qt) of the volume. Do they have a chamber and tested while engine is running, this chamber will have that amount hight of oil .... measure from there???? If it done this way, oil viscosity mighe effect the reading since it will have different flow rate.
I have 535xi ( the twin turbo engine ), iDrive told me MAX .... when new car out of dealership. My first change, I put 7qt, got MAX.... 2nd. I put 6.5qt, still got MAX.... I am going to start with 6qt next to see how it goes.
Old 05-18-2009, 03:09 PM
  #39
I was told there's one quart tolerance built into the system.
Old 05-18-2009, 04:02 PM
  #40
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
That's assuming the system is functioning properly...I'm all for technological progress, etc. [see my rants about SMG] but a simple dipstick is pretty darn trustworty and not prone to failure. It seems like a no-brainer for BMW to put them back.
Sometimes, there isn't a better mousetrap...
Quick Reply: Is That Dipstick back?
