Differential and Tranny oil leak!!
My Ride: 2004 530i, Silver Gray, Premium Pkg, Cold Weather package, Black Leather seats with lumbar support, Poplar wood finish.
Mods: M6 19" wheels with 245/35/19 Front Tires 275/30/19 Rear Tires, K&N Filter, H&R Sway bars, Magnaflow Muffler, Sprint Booster, Black front grill, M-tech front bumper, Debadged
Just got my car up on the ramp to change the engine oil and noticed that there was a leak in the differential! see photos.
I asked the independent service guy I was getting the oiled changed at and he said it's probably the seal/gasket and he will need to bring down the exhaust to get to it to replace the seal.
anyone else has had this problem?
if that's not enough I also noticed tranmission oil leak near the front since teh undercover had oil there. The oil pan has oil in it. Wondering what all I need to get changed there?
Out of warranty but have extended warranty (3rd party).
Any inputs will help.
thanks
~ V
thanks
~ V
that leak looks like the input shaft seal on your diff. its kind of odd to fail, unless you have a lot of miles, or you have movement in your pinion shaft. before changing the seal, make sure there is no side to side movement on the driveshaft to diff area.
I had the same issues as well as leaking valve cover gaskets and a leaking front stabilizer bar pump. BTW my 545 only has 49k on the clock. These cars are notorious for these problems. I also have a 3rd party, Mercury, that covered it all.
Did you take it to the dealer and have them work with the 3rd party warranty or did you use independent service?
I have also installed H&R anti-roll bars and a custom magnaflow exhaust, so I am hoping that doesn't void my extended warranty (through Warrentech)
I just have 54K miles. I'll check the pinion shaft too.
Is it hard to change the input seal or pinion seal on the diff.? Is there a DIY for it?
An independent told me that the exhaust will have to be lowered etc. ~ 4-5 hrs labor. The pinion seal itself is cheap ~ $40K.
well, half the battle is getting to the seal, but you also need to tighten the pinion yoke to a specific spec(?) after you change the seal.
An update:
I got the car into an independent shop and it's the mechatronics sleeve in the transmission which had a leak.
In the differential, it's the pinion seal that's leaking.
Good news - I got approval from my Extended Warranty company (Warrentech) to get both issues fixed (using BMW parts not aftermarket or refurbished).
That's $1200 saved that the dealer quoted to fix this!
