Differential Oil Change
Old 09-19-2012, 06:37 AM
  #21
Wolrab's Avatar
My Ride: 545i 2004, SMG, Sport, Nav, Logic-7, Bluetooth phone retrofit
The dealer apparently SELLS the nut and O-ring as one piece. They don't sell the O-ring by itself, or at least it's not listed in realoem as an individual part. My error in post #8. But you can discover in realoem that the O-ring size is M22X1.5 - see post #3. Then your choice is go and get the O-ring somewhere else (Oz equivalent of McMaster-Carr here), or shell out whatever the dealer wants for a couple of plugs-with-O-ring.
You're making way too big of a job out of this (unless you're just trying to run up your post count for some reason - nobody else had 8 live threads on page 1). More time has been spent on this thread than it takes to change the differential oil.
Old 09-19-2012, 04:49 PM
  #22
AchtungE60's Avatar
My Ride: E60 530i
OP - You're going to waste your time and money changing the differential oil in this car. Up to you. This is one of the only things I agree with BMW on. I have 400,000 + miles on my E39 2000 and never changed differential oil. I changed in my old 99 E46 when it had 130K or so on the clock and it looked good. I almost reused it.
Old 09-19-2012, 04:58 PM
  #23
kskane's Avatar
My Ride: E60 M54
Model Year: 525i 2004
Considering that you have noticed the time I spent on the forum, then it is all thanks to my beloved E60 which I like to keep instead of selling it cause there are no good Indy's and BMW guidance for maintenance is up its back entrance. I have got issues with my car starting from most common ones like engine oil leaks to most bizare and rare ones to Trans electrical one.
Plus, when I come for a totally non mechanical background, and realised what I had bought i.e. E60 then every single nut and O-ring makes the difference as I don't like to keep fixing the leaks but do it right the first time.
So thanks for your input so far.
Old 09-19-2012, 05:03 PM
  #24
kskane's Avatar
My Ride: E60 M54
Since I did the diff oil change last week, my suggestion to you is to change it. After 135K, the oil that came out was black and there was a lot of sludge or crap at the bottom of the differential. I have not heard too many issues on the Diff due to oil, but considering all the other problems I am facing, I just thought to go ahead and do this change and glad that I did.
Adam2022 (04-15-2023)
coolspot
05-07-2015 05:50 AM
demosthenesish
05-01-2015 06:02 AM
Steven06
04-08-2015 12:32 PM
Boland01
04-06-2015 10:25 PM
mantraguy
03-09-2015 02:56 AM
Quick Reply: Differential Oil Change
