Difference between "Sprint" and about 85% throttle?
Okay, so I have been noticing that the extra little bit at the end of the throttle where you have to give it a little more force for "wide open throttle" I think the bmw owners manual refers to it as sprint, doesnt make any difference at all. when I am engaging in some spirited driving, I hardly ever, IF ever give it that last little bit. even from a dead stop, whether it be in manual mode, DS or D, i dont notice a difference...
Is it just me?
Is there a true performance benifit to "sprint"?
Is it just me?
Is it just me?
Is it just me?
My Ride: '04 530d Executive, all options except sunroof and comfort seats
ECU remapped by ZipTuning to 260+bhp.
I've noticed a difference on my 530d.
When on 85% throttle (or just before the "click" to full throttle), it pulls to the limiter set by the current temp. (If it's cold, it'll pull to 4k RPM, if it's warm it'll pull to 4.5k RPM)
On full throttle it'll pull to the limiter at 4.6k RPM, no matter what temp your engine is running at.
Depending on which speed you are driving at, it also shifts down one gear more. (So for example from 5th to 3rd, instead of 5th to 4th)
is that last 15% also the "kick-down" where it automatically downshifts to pull harder?
Yep. Also, if your car is not in kickdown it will not rev past 4.5 to 5k RPMs. Only when you kick-down will you high rev up to 6.5k before a shift.
ucsbwsr
09-19-2015 10:58 AM
E61mendo
09-15-2015 03:55 AM
