Difference bertween fast, short route
Old Sep 30, 2006 | 07:23 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Right, but it can't use the current speed, it has to use some sort of average or every time you are in stop and go traffic, the ETA would "roller coaster" up and down rapidly. The average speed allows for smoother, more gradual ETA adjustments...
Old Sep 30, 2006 | 07:33 AM
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
If you watch the ETA you will sdee that it indeed goes up and down, but not that fast, because it has the predefined speeds you drive on this kind of road.
Let's say, you're driving on a highway, the predefinition is 130 Km/h (I have forgotten the real speed, just an example here), you get an ETA for the distance you have to drive this road (if your destination is at the end of this road, for this example). The ETA you get before you start driving off. While you drive, the computer calculates new. If you then only drive 100 Km/h, the time will be corrected and the ETA goes up. But because the difference is 30 Km/h it is not like a rollercoaster. But you can see the adjustment. It happens all the time! If you drive 200 Km/h your ETA will be corrected also. Then it will be very drastic.
The computer is not calculating with your average. The problem is, it calculates with those predefined speeds. And if the guys at navteq have marked the road as an highway, but it isn't, your ETA and all the routes you get are messed up.
Old Sep 30, 2006 | 08:05 AM
drjochen's Avatar
My Ride: 530i 6 speed
Originally Posted by Iceman' post='340282' date='Sep 30 2006, 11:04 AM
The calculation is made by predefined speeds.
City, outside of the city limits and highways.
Then you have the settings fast and short. When you select fast, you will get a route that brings you to the destination as fast as possible, all with those predefined speeds used. Short means, the shortest route will be given to you, that's the shortest distance between your current position and your destination.
So, for the shortest the distance is the main factor. If there is a possible way around town withusing highways, a fast route could bring up the longer driving distance around town.
In the end it's all programmed by somebody who is a human, and therefore, not perfect.
I have been in a situation were my destination was only 1 Km away from the point I have programmed the nav. It gave me a 7 Km route. Not the shortest, not the fastest. But once I left the route and drove the "correct" street, it adjusted.
Dealing with navigation systems means you need to be very patient.
...but the fast route is slower than the short route (not in real driving, but in estimated driving time shown by the NAV)???
Old Sep 30, 2006 | 08:07 AM
drjochen's Avatar
Originally Posted by EBMCS03' post='340155' date='Sep 29 2006, 08:22 PM
Hahahha its all software... you found another glitch in the matrix...
Hows the New E60 behaving? much better than the old one?
New car is fine. Only had the steering wheel sensor problem so far and several creaks and rattles. But if I want a quiet (...and boring...) car, I can drive my wife's Subaru.....
I am soooooo much happer with the manual (sorry, Rudy).
Btw., I recently drove a Audi DSG in Germany, no that is a gearbox I would buy right away - but that would mean buying and Audi and I am not 60 yet......
Old Sep 30, 2006 | 10:00 AM
Iceman's Avatar
Model Year: 2013
Now two things come to my mind:
First, if that happens when the car is still not moving, it could be an error, or it'sd just temporary, until a better/the best route is found.
Second, it happens while you drive, then there is a difference in between the speed calculated by tha nav for the roads you use, and the real speed you use.
Anyways, it's somehow strange to see, I agree.
Old Sep 30, 2006 | 05:00 PM
TXPearl's Avatar
Iceman, it sounds like you know what you're talking about, but I can say this for sure -- If I go well above the 'normal' highway speed limit for long enough, the Nav will adjust my ETA to a time that assumes that I continue to exceed the speed limit. Example: I have 45 mis. remaining, and it says I'll arrive in 30 minutes = 90mph. Therefore, as Rudy suggested, it must somehow take my recent speed into account in calculating the ETA, not just the predefined speed limit for the remainder of my trip.
Of course it could simply be an data error on the Nav DVD with the predefined highway speed !!
Thanks.
Old Oct 1, 2006 | 05:37 AM
DBU's Avatar
DBU
The "average speed" is the average speed the car has done over the last 30 miles (or so I have read). It makes sense that the ETA is then adjusted when there is a difference between that average speed and the expected speed assigned for that particular road.
Generally, I am impressed by the accuracy of those ETAs.
Old Oct 1, 2006 | 09:01 AM
Iceman's Avatar
Model Year: 2013
Originally Posted by TXPearl' post='340423' date='Oct 1 2006, 03:00 AM
...-- If I go well above the 'normal' highway speed limit for long enough, the Nav will adjust my ETA to a time that assumes that I continue to exceed the speed limit. Example: I have 45 mis. remaining, and it says I'll arrive in 30 minutes = 90mph. Therefore, as Rudy suggested, it must somehow take my recent speed into account in calculating the ETA, not just the predefined speed limit for the remainder of my trip....
Yep, of course. The recent speed, but not an average of the sppeds you were driving somewhen before. On this road you'r eon right now, you're driving faster than predefined speed is, so your current speed will be taken into consideration for the calculation on the ETA, for this road. On this road it's obvious that you can drive faster, and do. But once you drop much below the predefined, it adjusts itself back, so it works both ways, and therefore can't be the average speeds you were driving.
donmoha
Jul 16, 2015 08:31 AM
Inty
Jul 9, 2015 09:48 AM
pantzjantz
Jul 7, 2015 04:44 PM
gray545i
Jul 6, 2015 03:54 PM
Adam530d
Jul 6, 2015 07:19 AM
