Diesel Fuel pump problems
Did you read the codes by yourself?
If you did and with INPA software, you can read the specific modules separately and get some more accurate information.
If you read the error memory at the dealer/independent garage, I believe they can read the different modules too.
- Antti -
- Antti -
Thanks for your reply. I got it fixed. looks like the water in the boot caused the pump control box to blow a fuse. All good now. The box is now cover in insulating tape, hope that sorts it.
