Did My First Autocross in the 545i Sport
Old Jun 6, 2006 | 12:44 AM
  #21
heezy545i's Avatar
With AS automatically countersteering for you, do you think that may have contributed to your problems.
Old Jun 6, 2006 | 09:25 AM
  #22
jet190rs's Avatar
Yes! I almost forgot about that. That may have been the reason I was swerving after the apex, instead of AS changing the steering ratio when I apply throttle while unwinding the steering wheel, or a combination of both.
Is there a way to turn off the automatic countersteer? Is it off if DSC and DTC are off?
Old Jun 6, 2006 | 12:14 PM
  #23
heezy545i's Avatar
It's always on, even if you turn DSC off. I believe AS countersteers up to 5 degrees and intervenes faster than DSC.
Old Jun 6, 2006 | 01:02 PM
  #24
PoleApart's Avatar
My Ride: 2010 523i. Alpine white, dakota leather, 8 speed auto, VDC, bluetooth, HID lights, parking sensors, sport seats, black window trim, tinted rear windows 1988 Ferrari 328 GTS, nero on rosso corsa. 1992 Mazda MX-5 / Miata 2009 Ford S-Max 2.5T
Can anyone point to a techy link which describes in detail what are the active steering ratios at diofferent speeds and to what extent it countersteers.
I have a wide 90 degree turn on my way to work with a bus stop with spectators and I always turn DSC off and do a 2nd gear power slide/drift there. I've never felt the active steer countersteer there but I "think" it may have done this on a tight motorway access loop.
Przemek
Old Jun 6, 2006 | 07:22 PM
  #25
heezy545i's Avatar
This info dates back to '04, so not sure if anything has changed.
At speeds less than 45 mph, AS provides a 44 percent quicker steering ratio which is supposed to improve agility.
At speeds above 75 mph, AS provides an 11 percent slower steering ratio, which is supposed to enhance stability.
Transitions between the 10:1 and 20:1 steering ratio extremes are supposed to be smooth enough so that the driver doesn't notice. With no contribution from the electric motor of AS, the nominal steering ratio is 18:1.
  #26
heezy545i's Avatar
Here's a link that might be useful
http://www.bmwworld.com/technology/afs.htm
Hyper_545i
Apr 16, 2015 02:18 AM
SURYOYO
Sep 30, 2003 02:20 PM
Jun 17, 2003 09:38 PM
