!!!Dead Battery!!!
My Ride: 2004 545i - 6 speed manual (July 04 build), silver-grey/black, sports package std equipment (18", active roll, active steering, adaptive headlights), premium sound, bluetooth enabled, folding rear seat, lumbar, 3m hood/bumper protective film, rear tint, euro reflectors.
Originally Posted by my530i' post='272304' date='Apr 21 2006, 11:18 AM
E60 is totally different from Camry which does not consume much current in standby mode. In case of E60, there's a lot of electronic device and memory needs to be kept alive, so it's not a surprise to hear the car go dead after a couple of weeks.
I had one time while parked at the airport that the car did not shutdown and the battery was almost dead. There was also issues with older CIP s/w and accessories plugged in.
My point is that I would question the dealer on the issue and look into it further.
The problem is BMW does not have a definite solution for this. If not driving a car for 2 or 3 weeks, then disconnect the battery cable to avoid current drain. Otherwise, it's shame to ask a Toyota Camry to jump start a $50K car
![Wacko](https://5series.net/forums/images/smilies/imported/wacko.gif)
My Ride: 520d M-sport - Steptronic - Carbon Black - Auburn Leather - Mem Seat - Cup Holders - Nav Pro - Light Pack - Dim/folding mirrors - Adv Airco - PDC - Aux/in - Non-smoke pack - De-badged - Delivery Mar 31, 2006
Originally Posted by Ricracing' post='272099' date='Apr 21 2006, 11:25 AM
I just read a car test with the 116i.
The testers left the car in the garage for a weekend
but they didn't remove the "key" (it was with the start/stop buttom)
and the car did go completly dead.
Originally Posted by The Shrike' post='272102' date='Apr 21 2006, 02:36 AM
That is a shame. Why buy a car like this and drive a Camry all the time. ![Nono](https://5series.net/forums/images/smilies/imported/nono.gif)
The reason is I work in L.A. and there's tons of construction going on with loose gravel and other debries on the road, which are easily kicked-up causing minor dings and scratches on the hood of my Camry and I surely don't want that to happen to my E60... :'(
I mostly drive on the weekends but due to travel I haven't been able to drive it consistently and hence the reason to get a trickle charger!!!
Mine sat in the garage for over 2 weeks when I went on vacation last aug and when i came back the car started right up just as if I drove it the day before.
My Ride: On Order as of May 6- 2007 530i Titanium Grey and Grey Leather, with Sport Package, Premium Pkg, Cold Pkg.
2006 Porsche Boxster
If you have a DC power inverter this will kill your battery. i.e. if you want to run AC to a computer or TV and leave the power inverter plugged in this will kill your battery over time. Just make sure you unhook this from the outlet after using.
Many times I have returned from a long trip at the airport to find my battery dead.
Hope this helps.
Hope this helps.
My car sat in the garage for ten months. My wife started it once a month but around the 7th month the battery went dead, but I jump started the car once I returned and all is well. I am going to get the lastest CIP update, plus I put in the AUX input and navi TV.
My Ride: 2005 545i with Sport Pkg, Nav, HUD, Cold Weather Pkg, Rear Shades
Originally Posted by jakethesnake' post='271931' date='Apr 20 2006, 06:23 PM
I called Irvine BMW (www.irvinebmw.net), and spoke with someone in the Parts Department. They told me that BMW makes battery charger, although its designed for models older then 2005. They don't have any chargers for newer models and BMW does not recommend using a trickle battery charger, since it may have an adverse impact on the electronics.
Thanks.
Thanks.
Any particular reason you do not want to follow the recommendations from the dealer on not to use a trickle charger??
Lenniz
01-10-2016 03:37 PM
Kbc
07-31-2015 10:07 PM
