DDE-CAS sync Problem
Old 09-21-2014, 11:35 PM
jeandersson's Avatar
My Ride: 2004 BMW 530D E60
Exclamation DDE-CAS sync Problem
Good morning,
I'm having a problem to execute DDE-CAS synchronization. The DDE have been replaced with a used one that was made virgin by http://www.obdtuning.se/ prior to installation.
When I try to use DIS to execute synchronization it claims that there is a voltage problem. I have a charged connected to the battery and a constant power supply connected to the clamps in the engine compartment. I'm not able to check the voltage in the "hidden menu" since there is to many fault codes that are appearing and stopping my access. But I can check the voltage with Progman and reads steady 13,6V.
When I try to preform the synchronization with Progman I get the fault code "E60-03-12-510, UNBEKANNTE I-STUFE". And will not get access to the menu to preform synchronization.
The car is a BMW 530D -04.
Any help or ideas to get me going again would be highly appreciated.
Thanks in advance and best regards,
Johan Andersson
gergnang
02-02-2021 07:29 AM
bbbamboo
09-17-2017 04:33 PM
RussHamel73
06-03-2015 08:24 AM
gaz
05-29-2015 06:11 AM
E60Japanese
03-23-2015 05:23 PM
Quick Reply: DDE-CAS sync Problem
