Daylight Running light sensor
Old 04-08-2005, 01:08 PM
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
Originally Posted by Ruf930' date='Apr 8 2005, 11:04 PM
[quote name='?gent99' date='Apr 8 2005, 02:01 PM']Where is the sensor?? Is it located next to the center speaker on the dash?? I often wondered what that little button-like protrusion was...
[snapback]113007[/snapback]
That little button is the GPS.
Read all your replies. What is strange is it changes from my wifes key and my key. Mine stays on all day, her's cut off during the day. But its good to know its normal. Thanks.
[snapback]113079[/snapback]
[/quote]
No, Rudy is right. It's for the sun. It's only on cars with advanced A/C.
Old 04-08-2005, 06:01 PM
Guest
Guest
Posts: n/a
Originally Posted by Rudy' date='Apr 8 2005, 02:51 PM
One sensor is where you describe, sticking up out of the center of the dash.? The other sensor is pressed against the windshield behind the rear-view mirror (near the rain-sensor).
One controls the auto lights, the other controls the relative brightness of the CID & MID in between the speedo and tach, I believe.
[snapback]113036[/snapback]
Are you sure about the one in the mirror? I think the sensor for the CID brightness is in the little pinhole in the center bottom of the CID bezel...
I very well could be wrong... But you have all the DOCs Rudy.
Old 04-08-2005, 07:09 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
[snapback]113182[/snapback]
I posted everything without looking at TIS for any verification so I could be wrong. I'll go look it up now to see what's up...
Old 04-08-2005, 07:25 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Okay, I've verified (from TIS) that the thing sticking up in the middle of the dashboard is the "solar sensor" for the automatic climate control system (also called "IHKA High").
The following is a quote that describes the function of the solar sensor...
The solar sensor is located in the middle of the dashboard.? This sensor is only active in automatic mode.? The solar sensor takes external sources of light or heat (e.g. direct sunlight) into account, which could affect the air conditioning of the vehicle interior.
The sensor consists of 2 photoresistors.? The sensor transmits an analogue signal to the IHKA control unit for each side, driver and front-passenger, depending on the intensity of the sunlight at each side.
I've also verified that the light sensor is combined with the rain sensor mounted in the rear-view mirror pedestal.
The following is a quote describing the function of the rain/light sensor...
The rain/light sensor is integrated in the rear-view mirror pedestal attached to the windscreen.? The rain/light sensor is a combined rain sensor and ambient-light sensor.? It detects the amount of rain falling on the windscreen in order to control the windscreen wipers, and the level of ambient light in order to control the headlights.
Finally, I found that the brightness of the CID (iDrive screen) comes from an integral phototransistor. In order to control brightness correctly, the CID evaluates the following signals:
1) the dimmer signal from the light module (dimmer rheostat setting)
2) signal from the central photocell in the instrument cluster
(According to the TIS, the display brightness (offset of brightness) is also adjustable in the "settings" menu under "display settings" then "control display." Specific wording can change with CIP software updates, etc.)
Old 04-08-2005, 10:02 PM
KYRIACOS's Avatar
My Ride: DMS 535d. Titanium Silver on Black leather. M- Sport Package.
Originally Posted by Ruf930' date='Apr 8 2005, 07:01 PM
Searched the forum but could not find an answer...? Is there a sensor on the running lights?? When I turn my key to the left and leave it, I was under the assumption that the lights remain on all day.? However, I noticed that now they turn off during the day and turn on at dusk.? Normal?
[snapback]112958[/snapback]
With software 16.1 DRLs can be set by the owner in the vehicle settings lights section
Old 04-09-2005, 01:27 AM
niktee's Avatar
Location: Proud citizen of THE UNITED STATES OF AMERICA and MORGANTOWN, W.V.
My Ride: '05 530i, Premium, Steptronic, Logic7, Silver grey-black leather. Build date 12/7/04.
Daytime running lights is an idiotic concept. I don't buy the safety issue, either. If that's the case, why not program the horn to SOUND CONTINUALLY, or insist that all vehicles be painted with day-glow paint strips. Same lame argument, IMO.
DavaiLave
08-02-2022 02:16 AM
thesalboy
04-08-2015 09:13 AM
sh71jj
03-23-2004 09:52 AM
Jeff in VA
03-18-2004 09:57 PM
08-12-2003 11:41 AM
Quick Reply: Daylight Running light sensor
