In Dash CD player issues...
My Ride: E90 M3
Model Year: 2011
Did a search and found this mentioned one or twice but no firm resolution I could find. My '04 E60 has no navigation and the 6 disc player in the glove box, which works fine. The single in dash player has been acting up for a while now, though only sporadically. It makes that TATATATATA sound and won't play a CD. Usually I have to stop and re-start the car but somtimes that doesn't resolve the issue. Next time I start the car it will work fine. It was working fine this morning.
The car is now at the dealer for the squeaking brakes, rear brake replacement and microfilter replacement. I mentioned the CD issue to the service adivsor who said something about opening a PUMA case for the problem. I know others have had this problem, just curious what was found and how was it resolved. Was the player replaced? Is it a software issue? My car has something like CIP 18 which was done back in July 2005 to resolve the transmission slam issue.
Thanks in advance for the help!
My Ride: E90 M3
Model Year: 2011
Originally Posted by Rudy' post='401789' date='Mar 12 2007, 10:18 AM
Are you using a commercial CD or one that you burnt?
If commercial, I'm thinking you have a finicky player...
My Ride: 530i
It seemd like the CD player is getting out of alignment. If your car "co-operates" so you can replicate the fault while at the dealer they should replace the CD player.
My Ride: E90 M3
Model Year: 2011
I've had two M-Ask units replaced because of this issue, both times those were commercial CDs and a shame to loose (CD was not returned). Same issue, CD won't eject (Even after shutting down and re-start). Now the unit I currently have has started doing this again (Twice so far, last one this past weekend) but the shutting down and starting again has worked so far.
My Ride: E90 M3
Model Year: 2011
My Ride: 525d, build 3/2005, Silbergrau, Steptronic,Servotronic, Trailer tow hicth, Through-loading system incl ski bag, Cruise control, Winter packet
Hi!
I had exactly the same issue in my 525d from 2005. Local dealer changed the CD-player and updated CIP (in warranty),
no problems after that. Mine did this TATATATATA sound especially, when I leaved car for 5...60 minutes,
very seldom when parked her overnight.
My Ride: E90 M3
Model Year: 2011
Originally Posted by PJH525dA' post='401895' date='Mar 12 2007, 02:35 PM
Hi!
This is exactly what I'm experiencing! No jams, just the occasional non-play, sometimes with a message on iDrive that "Medium Cannot Be Read". Guess I'll be getting a new CD player. Was kind of holding out hope for Wiu-Bimmer's solution (new M-ASK unit) with the possible added benefit of picking up MP3 capability.
Edit: This reply only applies to US Specs, no Nav, early production date E60s (Up to 03/2005 I believe)
Unfortunately no MP3 funtionality added with new M-Ask unit, sorry. Yep big bummer.
The M-Ask unit that we have is BMW part number 65126942521, that is the unit that BMW service will replace your unit with (In my case twice already).
The M-Ask unit that the E60s that can play MP3 have is 65126942520 (At least this holds for US Specs E60s), there is a note on this part number that reads: ATTENTION: NOT MP3-COMPATIBLE UNTIL 03/2005.
You can check it out in http://www.realoem.com/
All I got was my settings deleted and a CD player that ejects CDs (And a CIP update)
