Curious Oil Level
My Ride: Current - MY2008 530i comfort access,active steering, HUD, prof nav/TV, bluetootth etc .....
Old - 2006 530i comfort access, active steering, HUD, NAV/TV, Bluetooth
The other day I got the message to add a liter of oil. So obediently I did and left the car overnight.
When I next used the car I check the oil level, the oil level indicator went up from the bottom of the scale to about halfway up. About 15 minutes later (traveled about 8k) the indicator was now showing full. And has remained so.
My question is what is going on with the oil that overnight it was unable to drain from the head to the sump and that even under load it took 15 mins to register full?
My Ride: 530i
Mods: M5 sporty package, M5 Steering wheel, Sprint Booster
Originally Posted by ricky1329' post='888858' date='May 25 2009, 12:45 PM
Yes and you should fill back a liter of oil. ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
I did and hence the question on the dip stick reading after adding the oil.
umichchris
12-10-2015 01:00 PM
