Creator c310 reading srs
My Ride: 525i
Ok I bought a new creator c310 for my 2004 525i. I have the airbag light on along with a restraint malfunction error. I was going through it and I can't seem to find were to diagnose the srs. Anyone know were in the unit the srs is under? Thanks
Probation Members
My Ride: 2006 525i, 2016 320i
Engine: N52
I used Creator 310+ to diagnose and Clear an SRS fault (93FC) on my 2006 525i . It’s a cheap scanner but does a lot for $55. I hope your scanner is BMW specific. OK, scroll around until you see “Body” or Chassis”. That’s where it will give you the code(s) effecting an SRS problem. My problem was low voltage (not been driving much during COVID). Ran the car a little, then deleted the code. Hasn’t come back. Hope this helps.
