Creaking Clutch
Old May 24, 2007 | 06:39 PM
bigfddi's Avatar
My Ride: '05 545i | Orient Blue | Blk Lthr | Sport | 6 Sp MT | Cold | Logic 7 | Sirius | iPod | Rear Heat | PDC | Rear SRS | NAV | HUD | AngeliBright Blue Up Next: New Radar Detector (Valentine 1 w/remote), SolarGuard 6% on all windows, Italian Euro Plate) '07 ML 500 | Alpine Blue | Blk Lthr | Pkg II | Lighting Pkg | Multicontour Seats | 6 CDC | iPod (Wife's Ride) Fond memories of: '03 540ia (the tightest car I ever owned!)
Anyone have this issue, when bringing the clutch back in, or pushing it down? If so what did you do to resolve it?
Thanks in advance
Old May 24, 2007 | 09:36 PM
Roleez's Avatar
My Ride: 2011 E92 335i M-Sport 6MT
I'm having that problem right now. Had the dealer re-lube the linkages but the sound is still there. Kinda resembles the sound of rubber. Not so prevalent/audible when it's cold outside (below 60 degrees), but is real loud/prominent when it's more than 70 degrees outside (and therefore way hotter inside the car). Gonna take it to the dealer again next week to have them recheck it.
Old May 25, 2007 | 12:30 AM
Jeffs's Avatar
My Ride: 2003 X5 3.0----->gone 2004 Porsche Cayenne S : Gemballa front and back bodykit, fabspeed bypass pipes, Gemballa exhaust pipes, full option, 20" factory sport design rims------>gone 2005 545i 6-spd manual---->de-badged, CDV removal, Autosolutions short shift kit, resonator removal, premium package, PDC, xenon, almost full options, hardwire V1 install ....looking for mods... 2007 550i 6-spd----> Premium package, sport package, Logic7, heated everything, Rogue Engineering SSK, CDV removal, hardwire V1 install, aFe cold air intake, Custom Magnaflow exhaust....
I had the same issue. Mine creaks only when I push it all the way down. Nothing the dealer could do to solve it. All i did to remedy the situation is to only use 1/3 of clutch pedal travel and creaking stops.
Old May 25, 2007 | 10:50 AM
yapaul's Avatar
My Ride: 2006 BMW 550i, 6s manual, Titanium Gray / Black Leather, M AeroKit, Sport Package, Cold Weather Package, Navigation System, Comfort Seat, Heated and Folding Rear Seats, Rear Sun Shade System.
My clutch made a squeaking sound when pushing in and letting out the clutch pedal. Very annoying. Since I could reproduce it, I showed it to my SA. They actually replaced the clutch! But the sound came back about a week after I got my car back. I took it in and showed the SA. The second time, they did fix it. They said they had to take apart the dash to replace some linkage or bushing (?). Anyways, it was all covered under warranty (this happened about 5 month after I purchased the car) but it took them about 2 weeks total to fix it properly. But that noise was most annoying and I am glad it is gone.
Old May 25, 2007 | 06:31 PM
bigfddi's Avatar
Thanks all!
Old May 25, 2007 | 07:11 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
The following post from last year also supports the fact that the squeak may be fixed under the dash...
http://forums.e60.net/index.php?s=&sho...st&p=326625
Also, mrbelk had a squeaky clutch pedal back in 2004 but I don't know what the outcome of the service was...
http://forums.e60.net/index.php?s=&sho...ost&p=14798
Old May 25, 2007 | 07:14 PM
bigfddi's Avatar
Interesting, thanks Rudy!
Old May 26, 2007 | 11:52 AM
fraseman999's Avatar
I have a great fix for this problem. Put 1 gallon of petrol over the car and set it on fire. My e60 was at the dealer 5 times for this problem. Tried the old lube first, ok for about 2 weeks. Then tried a new clutch pedal and full assembly. Then more lube. Then new master cylinder. Eventually got it back and the pedal feels like crap. But the squeak did go away for a couple of months and it still gives a little squeak now and then.
I think it is something to do with the clutch and too much pressure on the pedal. Car is out of warranty the middle of july. So i have a rather large list for them.
Still have the stiff steering and also suspect the rear diff is needing changed as it is very noisy. And will also be trying to get a new clutch.
Old May 26, 2007 | 01:01 PM
AlB's Avatar
AlB
I do not have any sound with my clutch
Old May 26, 2007 | 02:18 PM
bigfddi's Avatar
Good luck... I am covered till 2011 with full support/maintenance but I want it fixed now.
