Correct 18" Rim for 2006 530i w/sport package
My Ride: 2006 530si Sport, on a boat as I type!! Orient Blue, Beige leather, premium package, premium sound, cold weather, steptronic, power shades, fold down rear seats, rear seat heat, park distance control, navigation & Sirius satellite radio.
Hello:
I just lost a fight with a chunk of concrete on a local highway, and wound up with a badly cracked and dented rim. I doubt it is repairable, and am just looking to get a new one. I have 18" style 123 rims, and the gentleman at the tire store (my tires needed replacing anyway...the chunk of concrete just forced my hand) told me that the part # stamped on the rim was #59561. When I search for that number, it seems indicate that #59561 has a 43mm offset and is for an all-wheel drive xi, which I don't have. I was under the assumption that my rims had a 20mm offset, but the part # on my damaged rim is throwing me for a loop. Can someone steer me in the right direction? I need to get a new rim asap.
Thanks!
Thanks!
Here ya go. I have the same 06 530i, here are some pics from my stock 123's. It does say IS20 which I asume is the offset.
and from realoem.com page
http://www.realoem.com/bmw/showparts...70&hg=36&fg=15
02 Light alloy rim 8JX18 ET:20 Part# 36116760616 $379.95
Wow...thanks a ton! that's the part number (670616) that I was expecting to purchase. I guess I have to call the tire store this morning and have them double check before I bite the bullet on a new one
Well, it's all cleared up. I have no idea where the first guy got the part number from. I called over there this morning (they have my rim still) and it is indeed part # 6760616 just like in your picture above. I have a new (used) one on the way, and can't wait to get that god-awful spare off of my car.
Thanks again for your help!
Here. they are ET 20
Light alloy rim
8JX18 ET:20
36116760616
$379.95
RealOEM.com * BMW E60 530i BMW LA wheel, star spoke 123
Light alloy rim
8JX18 ET:20
36116760616
$379.95
I have an '04 530 with the sport package. When I bought the car it had a set of winter tires on it on Style 116 wheels (7.5x17) but the original Style 123 wheels with somewhat worn summer tires (245 40R18s) came with it. Now that I've gone to put them on the car, I find that I can't rotate the tires front to rear because even though the tire and wheel size is the same for all four tires, two of the wheels have 'a deeper dish' or what I believe to be more offset than the rear ones. If I try to mount the ones from the rear on the front, they bind against the struts. The rear wheels however, look a bit peculiar because they are farther inside the wheel wells and the car looks to have a narrower track in the back. From what I can see on RealOEM and from other sources, there is only one offset for this wheel style, so I am confused. I noted that near the center of each wheel on the outside there is a cast in number. The fronts read 13, and the rears 8.
Can anyone help? Thanks for your consideration.
check the stampings in my pics above
Thanks for the response, CrckJck, but I still don't understand why my front and rear wheels have two different offsets, when realOEM.com shows only one part number with one offset for Style 123. If I wanted two more wheels that are the same as what I have on the front, I don't know how I would ask for them.
pcy
09-12-2021 06:55 PM
