Coping with the Ice Age!
My Ride: E46 330, E60 550 on order: Carbon Black/Natural Brown, 6MT.
Originally Posted by Westcoast M5' post='495258' date='Nov 16 2007, 01:20 PM
Do you have kids? I grew up where winter temperatures reached -40C. By parents trained me by age 11 to go out and start the car, scrap the windows (at least what I could reach) and clear the snow off the car (as well as shovel behind it if neccessary). Now remember this is a car with a carburetor - give it some gas, but don't flood it it, don't expect it to start on the first turn, but be careful not to run down the battery, remember to unplug the block heater....
Boy, I just realized how easy my kids have it.... think I will make up a job list for them this weekend....
My Ride: Alpine White F11 520D SE 2013
Originally Posted by Cojones' post='495305' date='Nov 16 2007, 11:34 AM
Ah, brilliant...yes I do have kids. Hang on, he's only 3 months old, so how is he going to reach the windscreen?
Congratulations on your new son. It will be very interesting to see what your driving when he turns 16.
Originally Posted by iversonm' post='495264' date='Nov 16 2007, 10:31 AM
I never had to do that as a kid. I was far too busy walking 20 miles to school through snow and ice, uphill in both directions.
Only 20 miles, you were pampered as a child.
Originally Posted by Westcoast M5' post='495314' date='Nov 16 2007, 07:51 PM
Congratulations on your new son. It will be very interesting to see what your driving when he turns 16.Members
From: Europe, Netherlands, Near the (German) Autobahn
My Ride: 525d E60
I dont' have a garage so I have a few tips for you:
I bought a little electric heater with thermostat. I have a long cable running from the back of the house to the car and connect the little heater that is mounted on a flat board so that it never touches anything. The plug is IN the car and the cable runs via the door rubbers. In the house I put a programmable timer that turns it on approx 20 minutes before I usually take off. I also put a warning ' plug' in the key ' hole' to remind me to remove the cable from the heater.
Depending on the distances between your car and the house where you can put the timer safely (in my case no one can steal the cable and during the day there's no power on it so kids can't hurt themselves. Still I throw the plug over the fence in the morning to make sure there's nothing to play with. In your case you may be able to have the cable enter the door that you open to put your coat in or bag or whatever.
Found the above the perfect solution (if you don't have a built-in pre-heater (standheizung) which is ridiculously expensive) in any car I've used.
Important points to put into place are:
- heater may not get tooo hot (overheat safety built in)
- interior materials may not get too hot (mount it on something so it cannot fall over and lean against the upholstery) I mounted mine on the back seat, blowing air diagonally through the car towards the steering wheel)
- electricity plug INSIDE the car (because someone can unplug it (I'm thinking of playing kids) however, outside may be a better idea considering driving off without unplugging. Therefore:
- do something to make sure you do not drive off without unplugging. I block the hole where the key fob goes, you can also lead the cable around the gear stick or something like that.
- use a programmable timer to make sure: it starts in time so the car is heated up slowly but surely without too much heat needed and: no electricity on the cable when it's not used.
When I get into the car, the windows are demoisted or defrosted, the interior is reasonably warm (I don't need to keep my coat on which is good as I don't like to drive for over an hour with it). I do put the vent on the minimal position so that the heater starts working but does not start blowing untill I'm 5 min's away. I found that it blows colder air than I have inside the car for those few minutes. But pushing 'off' makes it take longer to start blowing warm air. (or it seems so)
The door rubbers can be dried using 'talcon powder' (this is a straight translation, don't know what it is in English) It's the white, extremely fine powder that is used in shoes before long walks or to powder baby's buttocks after wiping. Avoid using greasy stuff, did that on another car and it gets dirty quickly plus when you scrape past it, it smudges your clothes. Also: it doesn't work very well.
Hope this helps your thoughts toward a solution.
About the kid solution: you may want to start training with de-icing the headlights?
umnitza
Sep 2, 2015 11:28 AM
robfrey1
Aug 22, 2015 09:57 AM
