Coolant Low Warning
#41
Originally Posted by benjihana' post='1073508' date='Dec 14 2009, 02:33 PM
as300z,
You've stared diligently at all pipes, hoses, etc that you can see while the car is running? Who did the pressure test? Is there a seep hole in the water pump - nothing there?
#42
Originally Posted by as300z' post='1073518' date='Dec 14 2009, 01:42 PM
I stared at all the hoses the best I can and didn't see any leakage. The dealer did the pressure test and ran it for 3 hours and they didn't see anything either. I'm not sure how to check for a seep hole in the water pump.
#43
My Ride: 04 545i silver grey, 6spd, comfort seats, L7, sport, cold weather, rear heated seats
Originally Posted by benjihana' post='1073495' date='Dec 14 2009, 02:20 PM
rparik01,
Ask him which hose and ask him to show you where. Then go here: http://www.realoem.com/bmw/showparts.do?mo...hg=17&fg=05 and find the hose he references. Check out Garry Romani, get your hoses and clamps and some BMW coolant, and replace the sucker if you feel up to it. $300 is most likely $50-$80 for the hose then 2 hours of labor. I'm guessing $50 and $250 in labor for a 2-hour job...
#44
Originally Posted by rparik01' post='1073563' date='Dec 14 2009, 04:01 PM
Haha after being on this forum, we all have the same instincts. I'm actually in the process of leasing a X5 from this dealership and I mentioned that to him. I also noted the fact that I have been there several times for the same issue that they diagnosed as the expansion box and some hose connecting it. He talked to the manager and they agreed to wave the labor and said the part is 129.99. I agreed to that price, but then checked realoem to find the hose. I couldn't find a hose for that price, so when I pick up the car tomorrow I am going to compare part numbers. Thanks for your response.
No hotrodding for me. Most of the time my 3 year old son is with me. Thanks for the idea of checking the oil. I will do that!
#45
Well I went to pick up my car and the bill was 118, with the part costing 110. I showed them the price from realoem.com of 87.15. They said their whole price was 92, so they don't know where this number came from. Anyways they matched the price for me this time. I didn't know realoem had no affiliation with BMW, so I kind of felt bad. Well I felt bad until I got in my car and noticed that my headlamp selector light was still flashing, so my adaptive headlights wouldn't turn. They gave me the loaner back and kept my car. Still no conclusion if the radiator hose fixed the leak.
#46
My Ride: 05 645ci Steptronic, Sport & Cold Weather Package, Black on Black with Blackwood Interior, PDC, Illuminated BMW Door Sills, Logic 7 Sound....Mods and pics on the way !
I also was getting the "low coolant" message and finally got it fixed yesterday. Turns out my expansion tank (container that holds the coolant fluid) was leaking. Replacement tank was $80...disconnect the hoses attached to the tank...unscrew the tank install new tank reconnect hoses.....$80 labor.
On the V8 there is also a very thin hose connected to the expansion tank that runs across the engine along the front of the engine bay....check this for small leaks also (a friend of mine who also had the low coolant message had a small tear in this hose) run ur engine and watch it to see if coolant is seeping out. this hose is very delicate...when replacing my expansion tank this hose tore and had to be replaced be careful....$35
hose #10 on diagram....
#47
The car has been in 3 times since December 28,2009 at a new dealer.
1st time)
Low coolant light went on spoke to BMW NA afetr other dealer couldn't fix the issue. BMWNA advised I bring it to another dealer. The new dealer replaced coolant tak cap and pressure tested it with now issues.
2nd time)
3 days after getting the cap replaced, I see a few drops of something on my garage floor that seems a little greasy, clear in color with a slight tint of blue. Dealer looks at the car and pressure tests it again with now issues found.
3rd time)
My coolant level low light comes on after it being looked at 3 weeks ago. On top of the coolant warning, i get oil level low warning. The oil was changed 6,000 miles ago. Dealer gives me the car back today stating the oil was 2 qts low and they ran a pressure test on the cooling system and nothing was found. They topped off the coolant again and gave me 2qts of oil and sent me on my way like all is fine.
I called BMWNA and i'm waiting for a call back tomorrow. I'm not too happy right now. Obviously something is leaking internal but the pressure check and eyeballing the exterior of the engine is their means of justifying all is ok.
HELP
1st time)
2nd time)
3rd time)
HELP
bimmerspeed
Frequently Asked Questions
09-01-2015 05:09 PM
spediegunz
08-30-2015 09:43 AM
