cool weather=good acceleration
Old 10-09-2006, 07:08 PM
  #21
Don Juan's Avatar
Originally Posted by my530i' post='343157' date='Oct 9 2006, 02:27 PM
You need to:
1. Dump the spare tire. Another 30 lbs saving right there.
2. Minimize outwear for yourself. Save 3 lbs
3. Do not eat for at least 12 hours, and you need to dump all your intake . Save 3 lbs
4. Take rear seat cushion out. Save 10 lbs
5. Take spare tire, left and right trunk covers out. Save 10 lbs
Another 56 lbs off your car
Anymore questions?
you forgot to end it with
PRICELESS for anything else there is always a faster car
Old 10-09-2006, 07:12 PM
  #22
AC_S5's Avatar
it should read, lauching with your SMG and getting it fix by the dealer
Priceless
for anything else there's a faster car
Old 10-09-2006, 08:33 PM
  #23
EBMCS03's Avatar
Ya theres a 7 min or 7 miles cool down for the M5. so I'm sure its pretty similar for the regular SMGs...
P.S. I've already lost the spare and jack. those things have been in my garage for about a year now. I figured with RFT I wouldnt use my spare anyways... I would drive home... Unless its a road trip then I put the spare back in. Otherwise no need for spare...
  #24
EBMCS03's Avatar
Priceless
Old 10-10-2006, 06:19 PM
  #25
znod's Avatar
Originally Posted by grogan545' post='341919' date='Oct 5 2006, 08:16 AM
Hi all.The weather has cooled down on the east coast so it's time for more testing.
I tried several runs this morning and had to learn my starting method all over again.It seems that I must modify my method several times during the year in order to get the best times.Today the best method was,DTC/DTS off,brake torque to 1200 rpm,release brake and push gas to floor.My best time is:
0-60........5.00
60'..........2.00
330'........5.72
1/8 time..8.72
1/8 spd...81.90
1/4 time..13.43
1'4 spd...104.70
0-100......11.55
Weather conditions as follows:
temp........56F
dew pt......43F
bar..........30.20
altitude....400'
humidity..63%
I am sure Zman will apply the proper correction factors when he has time .I am not sure if the factor will be a positve or negative number.I have a feeling it will be close to zero.
When are you west coasters going to do more testing?
Here they come g-man. Good luck.
Your density altitude:
Air Temp 56 (?F)
Altimeter Setting 30.2 (in)
Dew Point 43 (?F)
Altitude 400 (Feet)
Density Altitude 107 (feet)
Your pass results corrected to sea level:
Uncorrected ET 13.43 (sec)
Uncorrected MPH 104.7 (mph)
Corrected ET 13.415
Corrected MPH 104.82
Your pass results corrected to 500 feet:
E.T. 13.415 (sec)
Trap Speed 104.82 (mph)
Measured DA 0 (feet)
Corrected to 500(feet) DA
Corrected ET 13.486 (sec)
Corrected Trap Speed 104.26 (mph)
Corrected 0-60 (Znod's procedure) 5.056 (sec)
The corrections hurt you a tad, but still a very good pass. Way to go. I'll be getting out when the weather cools.
Old 10-10-2006, 07:16 PM
  #26
EBMCS03's Avatar
Man... those are good numbers for a 545. I swear some of you guys have a stronger 4.4L engine.
Old 10-11-2006, 12:33 PM
  #27
heezy545i's Avatar
Originally Posted by vegastrashed' post='341928' date='Oct 5 2006, 08:36 AM
I'll be in LA this weekend. I'm going to try and round up the usual Socal suspects. Hopefully, a few can make it. My initial thoughts were to wait for some 335s to join us but it would seem that the Meet thread over in e90post is idle. http://e90post.com/forums/showthread.php?t=28597
If you want to get some action via the forums, you'll have to post that in the general forum. On e90post, they won't even move the thread.
Old 10-11-2006, 12:40 PM
  #28
EBMCS03's Avatar
Hhahahah are you implying somthing here?
Old 10-16-2006, 12:03 PM
  #29
heezy545i's Avatar
In an effort to get some 335s to come out, I made a thread on the general forum of e90post
http://e90post.com/forums/showthread.php?t...p;highlight=545
Plenty of views, but there doesn't seem to be much interest. Maybe someone could chime in.
Old 10-16-2006, 02:39 PM
  #30
hollywoodtrash's Avatar
Joe please do not attempt any nude launches
Quick Reply: cool weather=good acceleration
