Continuous Fuel Pump Priming every minute drains battery
My Ride: 530 XI
My fuel pump keeps priming every minute after the car goes into sleep mode, this process drains the battery. I have hooked DMM to measure current and have watched it escalate every time the fuel pump primes.
My Ride: 2005 545
What year and model is your car ?
What sanjsanj said. If you pulled the fuse for the fuel pump and the amps are still going up every minute, then the problem isn't the fuel pump. Something else is happening - could well be waking the car every so often and doing something that takes juice.
My Ride: 2005 545
Like I mentioned , the EKP module controls the regulated fuel pump . Pull the 30g relay that should cut of power to the module which possibly is the culprit causing the drain , or the 30g relay itself can stick ,not cutting off power to the EKP
