Complete Electrical Rebuild
#71
Correct. The cabling from the plug to the balasts is clear, so he spliced the cabl;es to bypass the ballasts and connected them direct. So now I have all headlight functions except AE. I hear you on the MOST. I'd seen the same thing with a MOST optical test. It either starts at the CD-Changer or HUD, both of which I haven't sourced yet.
#72
My Ride: 07 550i Sports Package
#73
This weekend I did make some progress. I'd found a 545i at a local junkyard that I was able to get a number of parts off of. I got the wiper motor, AC head unit, iDrive screen and satellite module. This weekend I went to install the wiper motor, and we realized the old motor was not connected I reconnected the old motor an lo and behold the thing works just fine. So now I'll need to take the replacement wiper motor back and probably eat a $20 restocking fee. I have no idea why anyone would unplug the motor
The AC head-unit does light up and the controls respond, but I'm not getting anything coming through the vents, so this probably requires the blower motor to be replaced. I plugged the satellite module, and for the first time, I did see the red flashing out of one of the disconnected MOST interface points. So I'm waiting to get a replacement CCC, Cd Changer, HUD and L7 Amp that are all on order. Once those are all plugged in, I'm hoping I get something on my iDrive screen. Still haven't coded anything. I bought a used laptop that finally seems to have gotten through some of the process.
#74
I tried removing the steering wheel to replace the column switch but I can't get that bolt to move. Did you have any problem with that? The air bag is out, I just can't get that center bolt to turn and it is starting to really wear down. I was thinking about trying an impact wrench but I am scared it may break it.
#75
My Ride: 2006 BMW 550i
#77
Hmmmm, I quite can't recall what we used, but I'll take another look. Wrench should still have the thing on it.
I did drive the car to work today, so my first actual long range driving experience, and I noticed it has a knocking sound when in 1st and 2nd gear. Short search on-line, and it appears to be either the UV joint, transmission, or transfer case. I'll take it to a mechanic, because whatever it is, it's beyond my DYI capacity
It also grinds at times switching to 2nd gear, so I think it might be a broken tranny tooth.
I go to get it titled today
#78
I did a really dumb thing today The DMV lady asked if I got a base model or the fancy one. And as the words were coming out of my mouth saying fancy I realized I just royally f'ed myself
Simple words that cost the pocket money . I tried to ask her what terms specifically the screen was saying so that I could try to retract, but she said that her options say the exact same thing and the only difference is the cost.
Aaaaarrrrgh!!!!!
Aaaaarrrrgh!!!!!
#79
Aaaaarrrrgh!!!!!
Aaaaarrrrgh!!!!!
#80
As far as the blower motor, you're not kidding. I finally got the center console out, and yet to tackle the blower motor. Part of me just wants to replace the carpet and close it back up so I can start enjoying it, but if I don't do it now, winter will be back with us and I wouldn't have done it
How did you fair with your search for headlights? What do you have outstanding on your ride?
