Complete Electrical Rebuild
#42
Ideas... on why the car went dead??? I am sorry to say, but after going through the water damage thing, you are trying to chase down a needle in a haystack... all it takes is one drop of water in a connection to send the entire system into a tail spin. That wiring harness, if not dry, will give you issues for years. The monitors and sensors if not dry, will fail sporadically as corrosion starts. One day it will work and the next it wont. I think you have to be real systematic about the replacement and/or drying of everything... Its going to be a very frustrating run for you unless you do it right.
#43
First thing I'd do is take the battery out and take it to an auto parts store. They can run a test on it and make sure that the battery has not been sucked dry. I was able to take the battery out of my E46 and put it in the E60.
I agree the wire has nothing to do with it, as I yanked my back seats out pretty haphazardly and it still works fine. How are you jumping the vehicle? With the terminals in the hood or direct to the battery (not recommended as it could cause computer issues). One thing I've noticed over the years is the source vehicle has to have some guts in order for it to be able to jump it. For example a geo metro (extreme example) would not be able to jump the E60.
I completely agree with getting the entire carpet out and trying my best with the wiring harness. Right now I can't get the seats to move and that's why I haven't done it yet :/ Pretty soon I might just cut up the carpet to get what I can off and let the rest dry w/ humidifier and fans. I'm actually trying to get replacement carpet from different sources.
Originally Posted by jaycal3
If you dont get that carpet and padding up and that wiring harness dry as can be you are just setting yourself up for issues down the road. Corrosion takes time to set in - as does mold and mildew. Everything will look great until you start getting random warnings, errors and christmas tree lights on the dash along with a smell of mold which is a major health hazzard. Not sure the WD40 is gonna cut it. Every major piece of electronics from the battery to the engine runs off that harness - $8k worth of harness!!!! Get the rugs and padding up and out... set up the fans and dehumidifiers...
#44
My Ride: 07 550i Sports Package
[/quote]
I have been jumping it with different cars one was a saturn from a passer by the first time and a honda civic the second time and a tow truck the third time all woked fine. The box under the passenger seat is dry I think whoever had it already dried it there are signs of carpet removal. Most of my moisture is in the back area. My seats are moved all the way back so I can get to the front bolt but not the back. It seems there is some fault in the power supply because I went back to the car and it powered up when I opened the door, but went dead again after a minute or two. I usually jump it from the front but i also tried the back yesterday after it wouldn't power up.
DId you recieve any parts yet? I got a BMW TIS yesterday I installed it but didn't find it very user friendly. I also got some headlight bulbs gonna try those, not sure when. A little surprised we haven't got more people chiming in, Jaycal seems to be the only one interested.
[/quote]
#45
Did you recieve any parts yet? I got a BMW TIS yesterday I installed it but didn't find it very user friendly. I also got some headlight bulbs gonna try those, not sure when. A little surprised we haven't got more people chiming in, Jaycal seems to be the only one interested.
While doing that though, my brother and I were able to find that the fluids were filled with water. Engine oil and power steering. So the next thing I'll be working on is replacing all the fluids (Engine, power steering, brakes, differentials). Still waiting on my Light Control Module and if I can get that in and working I can take it for inspection and get it titled.
#47
Complete fluke. When trying to get the alternator replaced, I took out a couple of screws from what my bro explained was the engine oil radiator. I then needed to drive it back into the garage for better lighting. I didn't put the screws back in and drove it in to the garage. There was some fluid all over the engine bay and tons spilled on the floor. The color was nothing identifiable though as it was a milky beige color. Opening the cap for the oil fill and looking in there and there was definitely water (a watery oily mix) instead of oil. Also checked power steering reservoir and it was a similar thing.
#48
Small victory:
I got the LCM today, struggled a bit to find where it went as the connector had been tucked away, but once I figured it out, I plugged it in, turned the car on, and now I have hazards and instrument cluster lights up!! WHile back there I saw a couple of unplugged cables, so now I just wish I had a complete E60 that I could use as a blue print for what the hell my car is missing.
Anyway, after doing all that, the rear view mirror now has something flashing, so the previous owner probably took out the LCM to save on battery since the alternator was out...
Anyway I'm excited about this small victory . For the steering wheel controls, I'm going to start hunting to see what module could be out.
#49
Small victory:
#50
So I had to cut up the front carpet as I'm not making any quick progress in getting the seats to move. I have the fan on it now and will be putting a dehumidifier in there tomorrow.
