Coil Over owners beware
Old Sep 29, 2011 | 06:23 AM
  #21
525iEnjoy's Avatar
Success. Well at least for the time being. I will follow up with some pics later today. I do have a little more clearance from my control arms. Again I am not posting to scare anyone from these mods, just beware and research . I am gonna still look into adjustable though. I am still confused why this happened.
Old Oct 4, 2011 | 08:30 AM
  #22
525iEnjoy's Avatar
update:
Looks like my FCP replacement end links arent quite stock specs. Once I get the specs from an OEM part I will ordering up new adjustable endlinks. May also check into rear ones too
Old Oct 4, 2011 | 08:37 AM
  #23
jgt's Avatar
jgt
My Ride: E60
Engine: N52
Originally Posted by 525iEnjoy
update:
What do you mean? They are longer, shorter?
I ordered a set of front sway bar end links from FCP and they looked identical to the stock ones I took out.
Old Oct 4, 2011 | 11:29 AM
  #24
525iEnjoy's Avatar
Stockers are 12'. Mine were 12.1875.
I have to pretty much go take out my links and adjust everything back to stock position and measure. So thats the update
Old Oct 4, 2011 | 11:35 AM
  #25
jgt's Avatar
jgt
My Ride: E60
Engine: N52
Weird. I think I would've noticed the difference since I lined them up side by side. Looks like I'm taking out the tape measure.
Old Oct 4, 2011 | 07:18 PM
  #26
525iEnjoy's Avatar
Update again ...
I took the links off remeasuredand they are 12inches(300mm). But the measurment from where the sway should sit is 60mm difference (240mm).
Old Oct 6, 2011 | 04:28 PM
  #27
525iEnjoy's Avatar
The sway bar should be towards the front which is down and right not toward the control arms
I want to change what I said I meant to say up and to the left. The bar went down it would really bind. so just to clarify
New links shipped out, should have them next week. PIcs and all that I will post up.
Old Oct 6, 2011 | 08:50 PM
  #28
G530's Avatar
Thanks for info. I'll be sure to take a peek in the morning or pay u a visit to have mine analyzed.
off topic - I need to consult with you on tire size again, need to get right tires setup for new wheels.
Old Oct 10, 2011 | 07:22 AM
  #29
525iEnjoy's Avatar
Today is d-day. Should be getting the links this afternoon. I believe the KW is installed at the maximum height but its max height is still less than my Koni's mounting position..see the picture where the pinch bolt is and the bronze insert. Its this slight variance that's causing my issue. Also see the tire/rim space I wish the made a 10mm spacer or even an 8mm that would fit snug. In theory I could get a 285 tire in there .. ha ha
Old Oct 12, 2011 | 06:24 AM
  #30
525iEnjoy's Avatar
Final update: finally got the parts and here you go! The first pic is of the 2 links side by side , I pre-measured the new one and you can see the difference on how far the sway was off. The 2nd pic is installed. Once installed they are a snap to adjust.Also see how the link sits above the control arm instead of on top of it. Thanks for following.
