Coil Over owners beware
Old Sep 23, 2011 | 07:00 AM
525iEnjoy's Avatar
Of the possibility that we as owners might need Adjustable sway bar end links. After getting service on my car the tech told that my sway bar has shifted to the right and is binding due to the non stock height of the coils and the long stock end links. the adjustables cure that issue and give your geometry back and the sway bar functions normal. My response was do you know how many have coil overs that haven't installed those. So I am posting this for the owners who are unaware like myself. Deer in headlights lol. I am sourcing out a set for the E60 and will relay that info
Old Sep 23, 2011 | 08:46 AM
toyota2bmw's Avatar
I am interested in what you find on this subject. What your tech said does seem logical and could be problematic in the long run. As someone who plans to keep my E60 around a while longer, I'd be concerned if coilovers have an adverse effect on the OEM geometry.
Old Sep 23, 2011 | 11:34 AM
525iEnjoy's Avatar
The sway bar should be towards the front which is down and right not toward the control arms
Old Sep 23, 2011 | 12:04 PM
525iEnjoy's Avatar
hope in sight i think. Turner Motorsports has one within spec of my stock link. Still confirming
Old Sep 23, 2011 | 12:13 PM
balbs's Avatar
My Ride: BMW
Funny I've always wondered about that. "If the car is lowered, won't the swaybar have more stress on not just one as in when cornering, but both sides of the axle even just standing still?" Subscribing since I'm debating getting coilovers.
Old Sep 23, 2011 | 10:10 PM
Isaiah_Charles's Avatar
Subscribed
Old Sep 27, 2011 | 11:30 AM
525iEnjoy's Avatar
update:
Have talked to quite a few on this ... i will be taking sway off and links to measure and confirm everything is where is suppose to be.
Old Sep 27, 2011 | 11:33 AM
balbs's Avatar
My Ride: BMW
I noticed that some aftermarket swaybars described as adjustable. What does that mean? Does it mean it's for the end links?
Old Sep 27, 2011 | 11:37 AM
pjinca's Avatar
Sort of, adjustable sway bars mean you can adjust the tension on the bar making it stiffer if you want. The ends of the bar itself have (usually) 3 holes where you can insert the end links into. What 525Enjoy is talking about is adjustable end links, which is different, adjustable sway bars are adjustable for stiffness, adjustable end links are adjustable for setting the geometry of the suspension to where you want it to be. Most of the time when they make adjustable end links they look like tie rods.
Old Sep 27, 2011 | 11:38 AM
jgt's Avatar
jgt
My Ride: E60
Engine: N52
That's exactly how you adjust the sway bars. By changing the geometry and position of the end link. H&R has an adjustable front and rear bar.
