coding/registering battery help
My Ride: 530i
Engine: M54
yes I searched, couldn't really find my answer so here it goes:
battery took a dive yesterday, the car has only has two batteries in its whole life; the original 110ah FLA from when it was produced, and a 90ah AGM battery that was replaced in 2008. So the car got 8 years from the last battery. I can't complain.
Today I picked up an OEM replacement from the dealer (I have a wholesale account), the 90ah AGM battery that I had in the car has been superceded to a 92ah AGM battery. I installed it today but haven't driven the car yet.
I was going to simply register the battery since I assumed that the dealer did it properly in 2008 when they replaced the 110ah with the 90ah AGM. Before I did that, I thought "eh, let me check the string in CAS to make sure it's right.... IT WASN'T. CAS has the 'klasse_batterie' string set to '110ah', so thanks BMW of Sarasota for not doing it correctly way back in '08.
so my question is, can anyone confirm that I need to change the string in CAS to "90ah_agm", or is it just "90ah"? my other question is I'm pretty sure I need to change the VO for the correct battery type, is the correct string "-A090"?? I know what to do and how to do it, I just need to confirm what those two strings should be.
thanks
thanks
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
thanks
thanks
Salut, Bob P.
My Ride: 530i
Engine: M54
Can anyone confirm that those strings are correct? Last night I did the following:
-changed +B110 to +A090 in the VO
-coded "klasse_batterie" from "110ah" to "90ah_agm" in CAS module
-registered battery using INPA
I reread CAS, I can see the new string for battery class took. When i look at values in INPA, battery capacity is shown as 91ah, which is correct (battery is 92ah). The one thing I didn't do is change the battery class string in LMA.
anyone? anyone? Bueller?
My Ride: e60 530i e21 320i
Model Year: 2005 1981
Engine: M54 M10
I don't know that it is necessary to update LMA module. The only other thing I would do is ensure the new AGM battery is completely charged before you do the final registration. When the battery is registered, the stored energy history is deleted. This allows the IBS to pickup the current state of charge.
My Ride: 530i
Engine: M54
Battery was fully charged, it was brand new from the dealer and they had just had it dropped off by Exide the day before. I didn't drive the car at all before coding/registering.
I remember seeing in ISTA/P the option of encoding battery retrofits. There were agm version and non agm version so pretty sure you need to code in the AGM option, which you did.
My Ride: 2004 545i+BT+AUX+Coding
Engine: N62
OK thanks for the input! I didn't think coding LMA was necessary either, that's why I didn't bother. CAS is the important one.
Also your experience will make me verify my dealer did the change toAGM properly 6 yrs ago with the PO. Of my car....
pennetta
Feb 23, 2006 10:16 AM
