Coding ?
Old Jan 22, 2020 | 06:18 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Default Coding ?
For the ones that know how to code, after coding does it take the night to actually take effect? Every time I code a replacement module it doesn't take the changes until after it sits over night. I can let it sit for a couple hours to let it go to sleep or pull the battery but it doesn't make a difference the changes don't take until it the next day.
Old Jan 22, 2020 | 10:43 AM
neilv's Avatar
My Ride: E61 530xi 6MT
Engine: N52
Depends on what you are doing. Some happened immediately(DRL settings), some I had to pull the key out and lock/unlock the car for it to take effect(exterior ambient lighting) and with other BMWs Ive seen it take longer(CCC-CIC adjustments+settings),
Some modules are big and I can see it needed to do some self checks and cycles before it switches.
Old Jan 22, 2020 | 06:58 PM
Ok. Well I think I have more coding to do. I changed my SZL coded and reset it but now getting the airbag and seatbelt light. I think now I have to restart the time on some modules. I'll see once I pull INPA up and check all of them. This DIY has become very cumbersome.
So to anyone changing a module connected to the airbag system it's not as simple as coding the new to you module. There's a lot of steps. Even after the many steps I've taken to get the SZL working correctly.
Old Jan 24, 2020 | 06:56 PM
I managed to reset the time. It was easy and just a couple of steps in tool32. Everything works as normal. Now to figure out this light issue. I'm just thinking I just need a new AHL module to fix it but I'm too cheap so it will probably stay broken. As long as the lights work I really don't care about to adaptive lighting
btatN54E61
Aug 9, 2018 05:47 AM
mkarlsen
Dec 31, 2017 10:23 AM
sirvri
DIY: Do It Yourself
Sep 1, 2014 03:54 AM
urabus040
Dec 6, 2013 04:21 AM
Shlooky
DIY: Do It Yourself
Sep 16, 2011 04:49 PM
