Code P0171 & P0174 ?
Old Oct 4, 2011 | 12:12 PM
syrousd's Avatar
My Ride: 2008 550I,Space Grey,Hud,Cold Weather,M - Sport, matched GP Thunder headlights and Fogs,,Smoked Badges, Night Vision, Heated Seats,Rear Sunshades, Aux Audio, SAT, NAV, Black Grills, Sprint Booster, Dinan Cold Air, Stage 2 Dinan Software.....More to come soon
Originally Posted by southgate
CRC Mass Air Flow sensor cleaner, bought it at Autozone.
CRC is pretty good stuff!!! I use it all the time on "rise Burners" on the waste gates!
Old Oct 4, 2011 | 12:13 PM
or_550i's Avatar
Originally Posted by NSBMW04
What did you use to clean the MAF sensor?
any pressurized canister of petroleum distillates and/or alcohol will work; i.e. MAF cleaner, Brake cleaner, electronic contact cleaner...
Old Oct 4, 2011 | 12:22 PM
roskinc's Avatar
My Ride: coilvers retrofits
Model Year: 2001 and 2011
id stick to the maf cleaner sprays, their only like 5 bucks at any auto shop. brake cleaner is like only couple bucks less but ive heard some horror stories of the brake cleaner being too strong for cleaning the maf. the sensors in the maf are very tiny, i always just use the maf cleaner, better safe than sorry, and always had good luck with em.
Old Oct 4, 2011 | 12:43 PM
AchtungE60's Avatar
My Ride: E60 530i
What horror stories? The MAFS cleaner and break cleaner and electrical cleaner is usually the same formula. There are thin metal wires inside the MAFS and they're not going to be hurt by any of the above products so whatever horror stories you've heard is most likely just inexperienced ranting.
Old Oct 4, 2011 | 07:05 PM
or_550i's Avatar
+1
There are always those who won't read the MSDS and know...
Old Mar 2, 2012 | 07:40 AM
texasporschedude's Avatar
I am having misfire code and now running to lean fault. the engine idle is very rough and fluctuates. Based on other post I was chasing the DISA as the problem. then I see this post and put two and two together I had the oil changed a few days prior to this problem. I see there is a comment about a crank case vent issue - How would you clear that condition. I will clean the MAF sensor to see if this fixes the problem. I pulled the DISA out for inspection, it seems sticky and had a good amount of build up. Is there a way to test the DISA before replacing it?
Old Mar 2, 2012 | 09:16 PM
AchtungE60's Avatar
My Ride: E60 530i
Only way you'll know if its the DISA is a dealer tool. It's proprietary which sucks. There is a physical and logical component.... look for my old post on the DISA. you'll find all kinds of caked up sand on it and so forth just clean it up. The flap is what usually breaks not the electronical component...although it could be that but doubt it. put it this way if the flap is fine and the electronical component does fail you'll know at idle because your car will sputter at idle but not at higher RPMs.
If you're running lean it could be several things start with maintenance first. when did you last check plugs? Clean air filter? Clean MAFS? is your oil cap on tight? etc etc. I bet you haven't serviced your air filter in a while...if using K&N make sure you oil only lightly and let it sit for a while to absorb...also clean your MAFS before running. YOu should be fine. What year is your car?
Zimo
Apr 11, 2018 08:25 PM
simonstothers
Jul 6, 2015 08:29 AM
Stranger12
Apr 5, 2015 10:42 AM
E60Speed
Feb 12, 2005 12:55 PM
wassy
Oct 27, 2004 09:36 PM
