Clutch Hydraulics
Originally Posted by AlB' post='514325' date='Jan 6 2008, 10:46 AM
I did the Dave Z CDV replacement due to the notchiness of 1st to 2nd shifts. As mentioned previously, I still need to be mindful of clutch engagement during normal driving conditions to get a smooth shift. Under hard acceleration, I do not seem to notice any notchiness.
I would suggest that you think about cahnging out your shifter if you decide to do the CDV replacement. It improves shifting from factory shifter plus a lot of the labor is duplicated on both processes. I have a Rouge SSK and am very happy with it. UUC also makes one.
good luck
al
good luck
al
Originally Posted by HotLap' post='513993' date='Jan 5 2008, 01:23 PM
+1 - Dave is great to deal with and if you have any questions he will take the time to walk you through it! I'm going to do the same with my '08 535 soon.
Originally Posted by gretamay' post='514520' date='Jan 6 2008, 07:25 PM
Rouge SSK or UUC, I'm not familiar with either. Have you a contact for them?
Rogue has shifter with WSR
UUC has shifter with DSSR
here are the links
http://www.rogueengineering.com/
http://www.uucmotorwerks.com/
here are the links
here are the links
http://www.rogueengineering.com/Merchant2/...gory_Code=ACCES
Originally Posted by DRANGED' post='514537' date='Jan 6 2008, 08:43 PM
Rogue apparently also sells Famous Amos Cookies
My Ride: 06 550-6spd
Originally Posted by gretamay' post='515309' date='Jan 8 2008, 08:50 PM
Thanks everyone for the info. Although I've had a number of manual shift BMWs, I just came out of a long relationship with some E23 745i Euro turbo cars and they are all automatics. So, I'm getting back up to speed, so to speak. I've got the Zeckhausen CDV enroute and I've ordered a short shift kit from UUC. Hope its got some directions for installation!
Originally Posted by Biff Trout' post='517087' date='Jan 12 2008, 11:23 PM
I have installed the Zeckhausen "modified" CDV and Rogue SSKw/WSR in both my prior e39 540i and my current e60 550i. Cannot say enough about both items. The "modified" CDV allows you to modulate clutch based on your years of experience. The Rogue SSK allows very crisp and no nonsense shifts. On my e60, I stopped at a friends shop, threw the car on his lift and installed both items on the way home from the dealer at 3 miles on the odo.
Originally Posted by gretamay' post='517416' date='Jan 13 2008, 04:45 PM
I don't have access to a lift, but I've got good ramps. Will ramps work?
You have to drop most of the underbody pans and the exhaust to get to the shifter linkage. Even at that, it is a grope/feel type of install. The CDV is easier to get to, but the bleeding operation can be tedious. It took me and my indy about 2-2.5 hours to do both on a lift.
keep track of the screws that you remove from the underbody panels. There are different sizes and the need to back in the same hole.
good luck
al
Originally Posted by AlB' post='517499' date='Jan 13 2008, 07:41 PM
I would recommend a lift.
good luck
al
good luck
al
On skill level, I would think that mid-level would be the minimum. You need to be confident of your skills because if you uninstall the stock shifter and don't complete the Rogue shifter install, your car goes on a flatbed to the dealer which would be quite embarrasing. Also, you absolutely have to have two people for the exhaust system removal and reinstallation. AND, it is best to have a two post lift for exhaust system removal although I performed the job on a single post lift after putting spacer blocks between the lift pads and the car's lift points to give the clearance necessary to thread the exhaust system out.
For the CDV install, you need a brake bleed bottle. I bought a Motive Products bleeder bottle which works perfectly. And finally from personal experience, when you install the CDV, make sure that you tie your clutch pedal to the steering wheel. If not, the pedal wil drop and push brake fluid down your arm and all over the place, a royal PITA.
