CID error
Old 04-26-2016, 03:17 AM
DanielFD's Avatar
My Ride: 2007 BMW 550i
Default CID error
Well i have a question, could the CID cause my CCC to boot in french and have Bluetooth stop working until i restart the CCC or I just leave it alone then it just restarts by itself after a couple minutes and fixes itself. This seems to happen about once a week, and the only error code I get is CID malfunction. Is the CID in charge of anything else other then just being a screen, does it house some settings or language profiles? any help would be appreciated.
Old 04-27-2016, 05:07 AM
BenAnd's Avatar
My Ride: BMW e60 525IA 12/2003
Bluetooth modul gone bad , common faliur.
Old 04-27-2016, 01:36 PM
DanielFD's Avatar
Thanks for the heads up. Ill read up on it. Do you think that could cause a CID error?
Old 04-27-2016, 10:18 PM
BenAnd's Avatar
Hi
Yes , it can make all kinds of faulty codes , try and disconnect the Bluetooth modul ( ULF/TCU ) , but remeber to make a loop on the LVDS cabel ( optical fiber cabel ) at the LVDS connector by the modul ( if you have Logic7,TV modul ,HUD etc. you will loose the sound if you not make the loop )
Old 04-27-2016, 10:21 PM
DanielFD's Avatar
Hi
I'll do that, i read up on it last night and i think your right. sounds a lot like my Bluetooth module is malfunctioning, i'm going to see if i can update it tonight and get a result, if that doens't work i'll go ahead and disconnect it. About the MOST loop, is there someway i can make a loop myself or am i going to go try and find a special tool?
Thank for the help
Vernon535
02-12-2016 06:37 AM
bunz
02-05-2016 04:54 PM
Andrew06
01-31-2016 05:38 PM
askim98
01-17-2016 01:23 PM
Chris Karolenko
10-23-2015 12:50 PM
Quick Reply: CID error
